Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old LED meter board repair
Old 18th March 2018, 11:31 PM   #1
SQLGuy is offline SQLGuy  United States
Default Old LED meter board repair
I picked up an HK TD392 cassette deck at an audio swap meet today. The lower three LEDs of the meter are out on one channel. I pulled it apart, and it uses a fairly monolithic H.E.C. H13A LT1151 board.
The board has two capacitors, two resistors, two potted ICs, and a one piece plastic module with two rows of LEDs.
I'm guessing that the symmetry of the parts means that they're using two separate driver ICs for the two channels of the display.
My question is around how the LED module is connected to the board. I do not see any through-hole pins for it on the back, nor any surface mount legs for it on the front. It seems to be held in place by six plastic rivets. I'm wondering if it's just using pin contacts that press onto bare copper pads of the board. If so, I wouldn't be surprised if these need to be cleaned, and that's why these three LEDs aren't working. Anyone ever removed the LED module from one of these things to check? Anyone maybe tried cutting off the rivets, cleaning the contacts, and then reattaching the module with some small screws?
Old 18th March 2018, 11:50 PM   #2
MAAC0 is offline MAAC0  Portugal
Pictures Please if You want some help
Old LED meter board repairHide this!Advertise here!
Meter repair for Pass Amps daly2k Pass Labs 15 9th December 2015 01:19 AM
U Meter Driver PCB Board Xabdeth Parts 8 24th September 2015 01:37 AM
wanted Yamaha B2 meter board eyoung Swap Meet 0 22nd October 2013 03:14 AM
A LED meter, Volt meter, power meter or light indicator... a nice gadget destroyer X Solid State 5 25th February 2011 06:30 PM
Id this power meter board DilbyŠ Solid State 0 19th February 2006 01:48 PM
