Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
S-Video to big TV
S-Video to big TV
Old 8th February 2018, 02:22 PM   #1
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
S-Video to big TV
Default S-Video to big TV
So, I would like to spend a maximum of $15-$20 to try to connect my old SD satellite receiver to my 60" plasma and try to get the best picture possible. It has composite and s-video output only.
As for the "stop just there and buy a used HD satellite receiver" comments, just bear with me, it's not that easy, and since I already have 4 SD receivers, I will always have at least 1 hooked up to a modern TV for years to come.
I believe s-video will give the best picture out of the receiver, better than composite. There are various inexpensive boxes I can try to convert from s-video to an input on the TV.
This one does s-video to VGA, about $CDN14:
1 Video S Video zu VGA Konverter AV Kabel Wandler Adapter fur Monitor Kamera ~~ | eBay
This one does s-video to HDMI, about $CDN20:
1080P AV S-Video To HDMI Audio Converter With USB Cable For HDTV DVD J1O6 X H4Q8 | eBay
This one is SCART to HDMI, about $CDN13:
SCART to HDMI Digital Video Audio Upscale Converter Adapter 1080P HD TV | eBay
The SCART to HDMI looks most attractive on paper, but wondering if there might be some hidden issues such as it doesn't support the s-video portion of the SCART standard, or doesn't handle NTSC well, etc.
For the s-video to HDMI adapter, since it looks cheap compared to its competitors, I would be worried that it simply did not work as advertised.
Any input appreciated, whether based on experience, or just general knowledge of video technology.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of Totò? Umberto Eco
Old 8th February 2018, 02:39 PM   #2
Samsara is offline Samsara  France
Hello.
S-Video is better than composite.
What is the input of your TV ?
Old 8th February 2018, 03:48 PM   #3
lcsaszar is offline lcsaszar  Hungary
Hello, sorry for threadjacking. I have the opposite problem: HDMI out to SCART (RGB) or to S-Video (or to CVBS in ultimate case). What can I use?
Old 8th February 2018, 06:40 PM   #4
You can use real HDMI to RGB converter but beware, HDMI have copy protection.
Maybe cheap converters don't manage it, you can find HDMI to YUV or to SCART (no RGB, only videocomposite) for 10€ in Aliexpress.
Old 9th February 2018, 03:22 AM   #5
leadbelly's Avatar
S-Video to big TV
This is the back of the TV:
Old 9th February 2018, 04:04 AM   #6
Pano is online now Pano  United States
Pano's Avatar
S-Video to big TV
S-Video is only better than composite if the comb filter in the receiver isn't great. Most aren't great. Since the SD satellite signal is probably composite anyway (over the air was) it's going to depend on where the better filter is, the satellite box or the TV. And if your TV has no analog inputs then you are at the mercy of cheap convertors. Your TV has no analog inputs at all?
EDIT: Just saw the pic.
Take the Speaker Voltage Test!
Old 9th February 2018, 04:31 AM   #7
leadbelly's Avatar
S-Video to big TV
Both composite and component analog inputs as in picture.
I just tried composite today. Looks mediocre with noticeable pixelation.
I am thinking the s-video to VGA is the safest of the cheap converters. I see the SCART-to-HDMI and s-video-to-HDMI boxes as being higher risk. I am not finding any inexpensive s-video-to-component boxes.
Old 9th February 2018, 07:32 AM   #8
Maybe you will have better quality with CVBS input to your TV than use cheap converter to YUV or HDMI.
YC to HDMI
1080P AV and S Video To HDMI Audio Adapter Converter For HDTV DVD-in Audio & Video Cables from Computer & Office on Aliexpress.com | Alibaba Group
YC to YUV Composite S-Video to Component Video RGB Sync On Green Converter
S-Video to big TVHide this!Advertise here!
Does there exist a video capture card that can capture rgb 240p non-interlaced video? Fusion916 Everything Else 2 2nd August 2015 07:00 PM
4 pin S-video to component video RCA GUS Digital Source 1 19th June 2004 01:05 AM
