Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Home with NO Ground in Electrical Installation
Old 21st December 2017, 12:07 AM   #11
Pano is offline Pano  United States
Pano's Avatar
For years I lived with split phase, no ground in France. There isn't much you can do if you can't make your own ground. You just have to live without, like our ancestors did.
Take the Speaker Voltage Test!
Old 21st December 2017, 12:36 AM   #12
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
Originally Posted by Shef View Post
You could use an isolating transformer for the 127-0-127 wiring, like some 600-1000VA toroid, connect it any way you want. IMO it also gives a bit of filtering from power line's noise.
I already used a 220V-120V 4.5kg stepdown Toroidal to the CD player for some time, when I removed it the sound quality increased instantly.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 21st December 2017, 12:37 AM   #13
PRR is offline PRR  United States
PRR's Avatar
Gentlebeings--
We have been through this before. This is NOT the power systems used in the US/Can, or the UK.... many systems are possible and Brazil is known to use several of them.
Originally Posted by FullRangeMan View Post
...does not have grounding, its bi-phase 220V (127V + 127V).....
Normally the metal shell of your clothes washer, and metal switch-covers, returns to a Protective Earth from the power company. Do you have that?
Old 21st December 2017, 12:53 AM   #14
Pano's Avatar
Yes. Metal water pipe has served me well in places with no ground wire.
Old 21st December 2017, 12:55 AM   #15
Originally Posted by petertub View Post
Connecting all device chassies together will cut all leakage currents, can be done with grounded ( 3 prong) cables connected to a 3-prong distribution connector. <snip>
Currently buildings have 3 pins (phase neutral ground to 127V or phase phase ground to 220V), but my condo is not this time.
The electric shower tap gave shock, then I solved the problem with a PVC pipe from shower to wall.
Old 21st December 2017, 05:45 AM   #16
PRR's Avatar
Originally Posted by Pano View Post
Metal water pipe has served me well....
...The electric shower tap gave shock, then I solved the problem with a PVC pipe from shower to wall.
He's getting shocked *by the water pipe*!
Connecting hi-fi chassis to this piping may be VERY DANGEROUS.
I wonder if you have a breakdown in the insulation of the electric shower.
I really think you should consult Expert Local Advice, not some hi-fi geeks 3000+ miles away who have never seen an electric supply such as yours.
Old 21st December 2017, 06:33 AM   #17
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
I would agree that it would be best to check with a local expert, but would not be surprised if the answer was "that's what it is". 2 prong 240V was normal not too long ago. My grandparents home in Italy is still wired that way, albeit uninhabited and eligible for free upgrade from the utility.
So if you have to make do with what you have, you need to look at things like GFCI and/or double insulated design techniques for peace of mind with your DIY projects.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 21st December 2017, 04:43 PM   #18
Originally Posted by PRR View Post
Gentlebeings--
All power outlets in my apto have only 2 phases wires.
Afew years ago I was using an aluminium window as ground as it near the system.
YOU RIGHT Here the situation is very bad, carpenters, locksmiths and electricians can not spell the alphabet.
Usually are unreliable people, especially if the client does not know the subject.
So Returning to the original question:
What grounding type/schema my tube amp should have?
Having groundless outlets on home.
Thanks for help
Old 22nd December 2017, 12:38 AM   #19
Speedskater is offline Speedskater  United States
Speedskater's Avatar
It seems that the two different common grounding systems are getting co-mingled again.
a] The Safety Ground/Protective Earth system. It's main task is to trip a circuit breaker in the event of a ground fault (short circuit). Most large exposed metal objects should be bonded (permanent connect) to this system.
b] The connection to Planet Earth. It's there for safety 1] during thunderstorms 2] high voltage failures (like if a high voltage wire falls on a low voltage wire) 3] to keep the Neutral at about the same potential as the swimming pool or damp floor.
Note the the connection to Planet Earth has nothing to do with day-to-day AC power quality.
Kevin
Old 22nd December 2017, 01:57 AM   #20
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
It is not one of these kind of showers by any chance. Shocks are common from them. The Latin American Suicide Shower - Argentina - WorldNomads.com
Home with NO Ground in Electrical InstallationHide this!Advertise here!
What kind of relay do I need? (home HVAC/electrical) Netdewt Everything Else 29 1st February 2012 10:20 PM
Hum, Noise, And House Electrical Grounding imfree707 Everything Else 0 15th June 2011 10:43 PM
mb quart PVI216 - installation in home ark Multi-Way 1 17th December 2010 03:27 PM
May I have some help regarding..Electrical safety,Star Grounding and Suggested Layout Tripmaster Chip Amps 69 10th April 2009 08:07 AM
