Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Ideal copper wire
Ideal copper wire
Old 28th November 2017, 09:10 PM   #21
R.I.P.
Originally Posted by 70s Veteran View Post
Hi Kevin, you are incorrect.
If you speaker - ve terminal is common then use it for 0 volts or earth (green / yellow wire).
The woofer can be connected to Brown wire (live).
The mid / treble to the Blue wire (neutral).
At the amplifier connect the Brown and Blue wires together and connect to the red speaker terminal +'ve.
Idea by no wiring a speaker is the the high current woofer waveform does not interfere with the lower current mid / treble speakers.
This does not apply to amplifiers. Like some bridge amplifiers.
you have been given an answer and yet you try to argue without understanding current flow.
regards Andrew T.
Old 30th November 2017, 10:08 PM   #22
chrisb is offline chrisb
Too much lack of understanding in this hobby that all of us are entitled to our own opinions, but not our "own" facts. Drill down deep enough, and I'm likely as guilty as anyone.
For most of the past 20yrs, I've never used anything thicker than the cheapest #18 zip cord available at the local Home Depot in my own systems, and challenge anyone to prove the advantages of thicker or "exotic formulas" / configurations in a blind test.
like my mind, this space intentionally blank
Old 2nd December 2017, 03:55 AM   #23
70s Veteran is offline 70s Veteran
Read about the benefits of bi wiring speakers on the net. All I was doing was proposing is to common the earth wire. Anyway cabtyre mains cable is near and can 16 Amps or a monster amp of 1 Kilowatt into 4 Ohms RMS instead of puny 5 Amps of el Cheapo rip cord of 5 x 5 x 4 = 100 watts .
Old 2nd December 2017, 06:48 AM   #24
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
So both currents are returning in this wire, hence, no difference
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 2nd December 2017, 04:19 PM   #25
So what, use two wires then. At least 16 Amp cable is far better than rip cord.
Old 2nd December 2017, 07:05 PM   #26
DF96 is offline DF96  England
I think 'alleged benefits' might be better. As I said, the main effect will be a slight dip near the crossover frequency. Ignore anything you read about 'interference'.
Old 2nd December 2017, 07:11 PM   #27
454Casull is offline 454Casull  Canada
Iím confused... why would someone parachute with copper cable?
Old 3rd December 2017, 11:48 AM   #28
Ron E is offline Ron E  United States
Ron E's Avatar
Bi-wiring - Some Results
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. óAldous Huxley
Ideal copper wireHide this!Advertise here!
cheap ideal guage wire reg66 Parts 6 10th May 2013 09:40 PM
diy build: questions about wire stators: ideal distance from each other and diaphragm Kardinaal Planars & Exotics 4 14th January 2013 03:14 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
Using enamelled copper wire tonga Solid State 9 13th February 2005 12:42 AM
Copper and Steel wire Chupa Car Audio 7 26th July 2004 07:34 PM
