Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Benchmark Media blog post about distortion
Old 24th November 2017, 09:52 PM   #11
Markw4 is online now Markw4
Here you go: Comodulation Masking Release | Auditory Neuroscience
"Comodulation Masking Release (CMR) is the decrease in masked thresholds that occurs when the masker is amplitude-modulated."
Old 24th November 2017, 09:56 PM   #12
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by DF96 View Post
1. it assumes that there cannot be any 'anti-masking' i.e. a sound makes other sounds easier to hear - this may be true but I am not sure it has been exhaustively demonstrated
It has been demonstrated that in some cases, where a tone is not audible, it can be 'unmasked' if another tone is added.
But I don't have the ref ready right now, I'll see if I can find it tomorrow.
Edit: It's complicated ;-)
Edit edit: Mark beat me to it...
Jan
ABSTRACT
A forward‐masking situation was investigated where more energy added to the masker decreased the threshold of the signal. The signal was a single sinusoid. The masker contained two frequency components: one at the same frequency as the signal, and one at a variable frequency. For certain frequencies and intensities of this variable masker component the threshold of the signal was lower than if that component were not present.This decrease in threshold is unmasking. Unmasking is interpreted as being caused by the suppression of the fixed masker component by the variable masker component, thus producing less masking at the signal frequency. The basic pattern of masking and ummasking was qualitatively similar to the pattern of pulsation thresholds observed by Houtgast [Acustica 29, 168‐179 (1973). Unmasking was not observed at absolute threshold or in a simultaneous masking situation. Unmasking was observed at all signal frequencies tested (0.5–6.0 kHz) and was not dependent on the phase of the masker components or the phase between the masker and the signal. When the frequency of the variable masker component was less than the signal frequency, unmasking was dependent on only the intensity of the variable component. However, when the variable frequency was greater than the signal frequency, unmasking was dependent on the difference in intensity between the two masker components. The existence of unmasking in a forward‐masking situation does not depend on whether or not the masker and signal are turned on and off abruptly or smoothly. These characteristics of unmasking are not in conflict with the assumption that this effect is caused by the variable masker component suppressing the other masker component.
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 25th November 2017, 02:02 AM   #13
mmerrill99 is offline mmerrill99  United States
As I said, it also occurs when sounds at different frequencies co-modulated with the masking frequency. These frequencies wouldn't be called maskers in the normal sense as they are remote in frequency from the signal being detected to act as maskers so that definition from Auditory neuroscience is better explained by the diagram on that page where it shows that a modulated masker becomes more effective at releasing masking as the bandwidth of the masker is increased.
As you can see from the diagram, the threshold for detection is the same up to about 100Hz bandwidth of masker - whether it is modulating or not modulating doesn't matter, threshold is unchanged - it's the increasing bandwidth that makes the difference in other words it's the remote frequency modulating signal that makes a differences as I said originally
Old 25th November 2017, 03:10 AM   #14
Just to explain further - the "CO" of the term co-modulation masking release is the important word fragment. It means that something else is modulating in synchrony with the masking tone NOT that th emasking tone itself is modulating.
When the other sound that is modulating is in a different critical band or ERB to the tone being masked, it reduces the amplitude threshold that is detectabe.
Old 25th November 2017, 11:15 AM   #15
DF96 is offline DF96  England
However, DF96 suggested anti-masking would be an effect that would make a sound that was below the baseline threshold of hearing when unmasked, more audible in the presence of, or when summed with, an anti-masking sound. The idea there might be that a sound below the threshold of hearing might be inaudible by itself, but maybe adding it to another sound could result in a composite (summed) sound that makes the low level sound more audible.
Yes, the point I was making is that the idea that distortion which is below the threshold of audibility is necessarily inaudible relies on there being no 'anti-masking'. That is, a sound below the threshold of audibility cannot be rendered audible by the presence of some other sound. Naively one might expect this to be true (given that masking has the opposite effect), but who knows whether there is some sort of parametric amplification possible in the ear or brain with certain combinations of frequencies?
Originally Posted by mmerrill99
Yes, the part I bolded is true - it's called comodulated masking release which does exactly what it says on the tin - when another frequency synchronously modulates with a masked sound it un-masks the masked sound
Thanks. I was not aware of that, but it makes sense. Just to clarify, this is a sound which would be audible if not masked, but it has been masked by a second sound, but is then rendered audible again by a third sound?
Old 25th November 2017, 11:24 AM   #16
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Lots of mights, coulds and maybes here, interesting, but why would one want to make inaudible distortions audible or is it purely academic?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 25th November 2017, 12:10 PM   #17
Gyuri is online now Gyuri  Hungary
Gyuri's Avatar
I'm wondering about it for a long time, we are worrying about frequency response of our audiosystem. We say for example, what a crap this power amplifier, it has a frequency response only +/- 1dB between 20Hz-20kHz.
Loudspeakers has a much more more deviances in this regard.
And how's about our ears?
I think this is the more important part of our audio system.
Even a young and undamaged ear has much more deeps and peaks than +/- 1dB, just for example as for my daughter as you can see in attachment:
http://www.diyaudio.com/forums/attac...ring-panni-jpg
And how's about distortion?
When my right ear was damaged lately because of unknown reasons, one of my complains was about higher perceived distortion.
Can we measure distortion caused by of our ears?
I haven't find information about it yet.
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 25th November 2017, 12:23 PM   #18
Gyuri's Avatar
Just a remark:
You can change everything in your audio chain, except your ears.
So you must to protect them just as it is possible.
Old 25th November 2017, 12:33 PM   #19
I think that's all you can realistically do. Most people don't though till it's too late...
Old 25th November 2017, 12:46 PM   #20
Gyuri's Avatar
Unfortunately while people are young, they consider the health as a natural thing.
Just like I was with this.
But it is not like this.
If you are healthy, regardless of your age, it is a present what you must to care and keep.
Benchmark Media blog post about distortionHide this!Advertise here!
Benchmark .... Madmike2 Digital Source 5 29th July 2005 05:05 AM
