Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Test your ears in my new ABX test
View Poll Results: Have you been able to discern the files in an ABX test?
Yes, I was able to discern the files and have positive result 3 20.00%
No, I was not able to discern the files in an ABX test 12 80.00%
Voters: 15. You may not vote on this poll
Old 11th November 2017, 09:04 AM   #421
PMA is offline PMA  Europe
PMA's Avatar
Karl, when analysing your Rotel 1kHz tone files, I can see that both of them have high level of background noise and spuriae. Therefore is difficult to evaluate amplifiers sonic contribution without having an original file. Would it be possible to post the original, level matched file, or, at least, the file recorded through direct loopback without Rotel in the signal path?
Old 11th November 2017, 09:16 AM   #422
maty tinman is offline maty tinman  Spain
maty tinman's Avatar
Default Moving my arms like an orchestra conductor. Multichannel 9.2
This means that I can not resist moving my arms like an orchestra conductor. And that is not very usual in me, I need to believe what I hear and get excited.
Years ago (2011), in Reus (Tarragona, Spain) I hear the Andreu big system, 9.2 (two big DIY closed 18" subwoofer). First with closed speakers and after with open speakers, all DIY.
With closed front:
Sala de Andreu. Campo cercano. MP3 versus FLAC. 16/44 versus 24/96. B2031P versus Trevi+sub. Campo lejano y multicanal. | Nauscopio Scipiorum
[IMG] http://maty.galeon.com/NB-imagenes/a...u-16042011.jpg
and the DIY open front
[IMG] http://maty.galeon.com/WP-imagenes/h...ipolos-III.jpg
With the front closed, rock, pop, jazz, classical... multichannel sounded very very very well.
With the front opened, the classical (multichannel) sounded AMAZING. The others music sounded worse than closed speakers.
PS: One day with the old dipole. Second day with the Behringer VP2520 without mods. Third day with the new dipole (picture above),
Old 11th November 2017, 09:47 AM   #423
The older big closed front: Matrix-Hifi: H.U.M --> MGornirl
Old 11th November 2017, 10:03 AM   #424
jcx is offline jcx  United States
Default LTspice IV .wav works at 24 bits 96k for me
Originally Posted by Mooly View Post
...Due to the limitations of exporting files in LTSpice the originals had to be down converted to 44.1k unfortunately...
don't know what you're saying here - takes too long, files too big, or control panel settings not giving enough resolution?
Old 11th November 2017, 10:17 AM   #425
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Originally Posted by PMA View Post
Until you have a chance to sit there or to use better source of sound. Do not make me laugh, the dynamics of the big concert hall you are never able to transfer to your home, and especially not through compressed FM.
I did have similar imaginations, but 40 years ago I was at the practice in Supraphon recording studios for one months, recording mainly the classical orchestral music. For the next 25 years, I stopped any improvements in my home hifi and considered all the hifi efforts as useless. Then I have humbly accepted the fact that it is absolutely impossible to bring a concert sound to my/your sitting room.
I have run 4 stacked large 12" 3 way cabs in my lounge room for a couple of years, somehow the neighbors never complained.
An Aus J1000CS with 500+ fair dinkum watts per side is a fun way of doing anything like justice to AC/DC, R.E.M, Hendrix and the like....the list is long.
At full tilt an hour or so on a bunch of favorite tracks once a fortnight was ample....the sound was dead clean and mega big (ie huge) but 'not loud', that hour was like a live rock show of your choice only better and was a 'fix' of sorts......the rest of the fortnight at 'normal' levels was fine after the full on experience.
So Pavel, yes for orchestral program and real dynamic range recreation I agree it can't quite be done in the home environment.....as for loud rock/blues that's a fun and different story.
Dan.
Old 11th November 2017, 10:18 AM   #426
Mooly's Avatar
This is the test track played on the Sony and recorded as before, no amplifier. I used the variable output on the player to get the level in the right ballpark.
Sony Direct
Old 11th November 2017, 10:21 AM   #427
PMA's Avatar
Thank you Karl! I have to leave now but will be back in the afternoon and will test it and make matching/alignment if necessary.
Old 11th November 2017, 10:31 AM   #428
Mooly's Avatar
I haven't been able to get it to create a file with any content when using other than 16 bit, 44.1kHz.
This would be a typical .op command that works for me:
Code:
.wave "C:\users\Karl\Documents\Working Files\level.wav" 16 44.1k V(out)
Just looking at the LT IV manual:
It says, and maybe this is the vital part applicable to my set up,
To read a .wav file with your PC's soundcard make sure that you limit its characteristics:
Format maximum of two channels.
Sampling resolution maximum of 16 bits per channel.
Sampling rate maximum 44100Hz.
I tried in the past and had no luck with anything other than 16/44100. I also thought it was all pure calculation and that the sound card didn't come into it.
Old 11th November 2017, 11:50 AM   #429
Default Ella Fitzgerald – Sings Sweet Songs For Swingers
Off topic
Ella Fitzgerald Sings Sweet Songs For Swingers {US 1st Mono Pressing}
foobar2000 1.3.16 / Dynamic Range Meter 1.1.1
log date: 2017-11-11 12:21:28
Analyzed: ? / ?
DR Peak RMS Duration Track
DR14 -0.77 dB -18.48 dB 3:15 ?-A1 Sweet And Lovely
DR14 -1.73 dB -18.68 dB 3:07 ?-A2 Let's Fall In Love
DR14 -1.51 dB -19.38 dB 3:47 ?-A3 Makin' Whoopee
DR14 -0.67 dB -18.43 dB 4:18 ?-A4 That Old Feeling
DR14 -1.69 dB -18.69 dB 2:25 ?-A5 I Remember You
DR12 -3.21 dB -18.93 dB 3:05 ?-A6 Moonlight Serenade
DR12 -1.51 dB -16.34 dB 3:03 ?-B1 Gone With The Wind
DR13 -1.86 dB -17.99 dB 3:25 ?-B2 Can't We Be Friends
DR12 -1.98 dB -17.16 dB 4:33 ?-B3 Out Of This World
DR14 -0.77 dB -18.20 dB 3:05 ?-B4 My Old Flame
DR14 -1.30 dB -19.14 dB 3:47 ?-B5 East Of The Sun (West Of The Moon)
DR13 -0.29 dB -16.34 dB 2:34 ?-B6 Lullaby Of Broadway
Number of tracks: 12
Official DR value: DR13
Samplerate: 96000 Hz
Channels: 2
Bits per sample: 24
Bitrate: 1539 kbps
Codec: FLAC
Ella Fitzgerald - Sings Sweet Songs For Swingers (1959) [Hdtracks 24/192]
log date: 2017-11-11 12:22:06
Analyzed: Ella Fitzgerald / Sings Sweet Songs For Swingers (24/192 Stereo)
DR11 -0.91 dB -14.74 dB 3:15 01-Sweet And Lovely
DR11 -1.02 dB -15.43 dB 3:06 02-Let's Fall In Love
DR13 -0.96 dB -17.22 dB 3:45 03-Makin' Whoopee
DR11 -0.91 dB -15.70 dB 4:19 04-That Old Feeling
DR11 -0.96 dB -14.88 dB 2:25 05-I Remember You
DR11 -1.58 dB -16.18 dB 3:04 06-Moonlight Serenade
DR11 -0.95 dB -14.92 dB 3:03 07-Gone With The Wind
DR11 -0.94 dB -15.11 dB 3:24 08-Can't We Be Friends?
DR12 -0.99 dB -16.26 dB 4:37 09-Out Of This World
DR12 -0.94 dB -15.23 dB 3:05 10-My Old Flame
DR11 -0.88 dB -15.54 dB 3:48 11-East Of The Sun (West Of The Moon)
DR10 -0.89 dB -13.20 dB 2:26 12-Lullaby Of Broadway
Official DR value: DR11
Samplerate: 192000 Hz
Channels: 2
Bits per sample: 24
Bitrate: 5418 kbps
Codec: FLAC
Hdtracks 24/192 sound brighter. After different tests I like more after resampler the HDtracks to 24/96 with SSRC Intermediate 95%
[IMG] http://maty.galeon.com/WP-imagenes/f...mediate-95.png
Resampler-V DSP plugin for Foobar download | SourceForge.net
Old 11th November 2017, 02:28 PM   #430
PMA's Avatar
DR14 is normal on vinyls of pre-computer audio era. Let's thank to pocket audio for this horrible overcompression we have on new recordings of popular consumer music and remasters of old issues.
Hopefully not so for classical music. The DR of the Toccata violin under test here was 14
Code:
foobar2000 1.3.7 / Dynamic Range Meter 1.1.1
log date: 2017-11-11 15:19:32
Statistics for: ?-tocl
Number of samples: 5518496
Duration: 1:55
                 Left              Right
Peak Value:    -11.41 dB
Avg RMS:       -28.89 dB
DR channel:     14.46 dB
Official DR Value: DR14
Samplerate:        48000 Hz
Channels:          1
Bits per sample:   24
Bitrate:           1152 kbps
Codec:             PCM
Test your ears in my new ABX testHide this!Advertise here!
Do you have Golden Ears? Take the test and find out maxw Everything Else 6 28th February 2014 03:19 PM
Ultimate listening test ... test your ears and audio chain PMA Everything Else 378 21st November 2013 11:20 AM
Jitter Test Signal (J-test Signal) with MATLAB merlijnv Digital Source 40 6th May 2013 05:36 AM
Test Signal for max power test of Class D? eem2am Class D 19 27th August 2012 10:22 AM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 10:24 AM
