Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Making your own lightning arrestor.
Old 27th October 2017, 07:34 AM   #11
VenusFly is offline VenusFly  Australia
VenusFly's Avatar
specs on this unit say its only got MOVs and there is no mention of any GDTs: APC SurgeArrest 6 Outlet w/ Phone, Protection PH6T3-AZ | eBay
SurgeArrest components such as MOVs and Thermal fuse ensure instantaneous reaction to lightning strikes and wiring faults. If the surge components are damaged due to power spike or over voltage, excess power cannot reach your equipment. Unlike the APC SurgeArrest products, most surge suppressors continue to let power through even after circuits have been damaged, leaving your equipment exposed to other damaging surges.
A freeman. Love your neighbours and Love nature. Stop cutting down trees to make houses a stones throw from your neighbour and join your real home, the rainforest.
Old 27th October 2017, 07:47 AM   #12
VenusFly's Avatar
Looks like I'm giving up on making my own and simply buying this:
DTA 1 Power Line Filter | eBay
http://precisionpower.com.au/pdf/PP-cat-2005-p16-1.pdf
Old 27th October 2017, 06:30 PM   #13
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Enzo View Post
If I am not mistaken, your 240v system has neither leg tied to earth. So two hots. Yes?
Almost certainly, his power is one leg earthed. "Somewhere".
However lightning surges are not susceptible to simple analysis. The rise-time is very rapid. The 50 feet from my house to the dirt-rods at my pole induces only 0.1V at 60Hz 100A but MUCH more for 30,000 Amps and 1-10us risetime (~~50KHz).
The EDN article is thought-provoking, but theorizes on cost reduction, and I don't see that it has been tested in lab or in field?
I like to theorize but I go with commercial products which have recognized testing.
You seriously want some SERIES impedance. Often this is factored as the impedance of the circuit wires.
You seriously want multi-level protection. I have a suppressor in my fusebox as well as at key appliances. Useful technical/sales sheet.
You seriously want to bond ALL your incoming wires together (per local laws and customs). I was losing two modems every summer, because the phone was overhead and the power was underground. The best path for induced aerial surge was through the modem. This would have helped. Also this. Properly installed!
If you are on a well there are other details. The pump is by far the best ground around the house.
Old 27th October 2017, 07:55 PM   #14
davidsrsb is offline davidsrsb  Malaysia
Gas discharge tubes are better at protecting dc circuits. They are slow to strike, so best used as the first stage of a two stage filter, followed by a MOV
Old 27th October 2017, 09:17 PM   #15
busaboy is offline busaboy  United States
A GDT alone should never be used Line-Line. Once triggered they are effectively a short.
An MOV has the nasty habit of catching fire when hit with a big surge. You need to use a thermal fuse in series or have a way of isolating the MOV from anything flammable.
Most surge protectors are junk. Even the average whole house type and even many "Industrial" Surge Protectors. The MOV they use are fairly wimpy and cannot handle the surge. One big surge and they die.
Old 27th October 2017, 09:51 PM   #16
Enzo is offline Enzo  United States
PRR, I had to ask, since 240 here in the USA has neither leg as neutral. Our 120v is half of the 240 feed. The neutral then is essentially a center tap on a 240v feed. I would have no trouble believing their 240 is similar, meaning neither leg of 240 is really neutral.
Old 5th November 2017, 10:40 AM   #17
Pano is offline Pano  United States
Pano's Avatar
In France that was always the case, each leg was 110V above ground. Meaning if you got shocked hot to ground, it was less of a bite. When I lived in the UK I assumed it was the same, but can't remember now. It's not difficult to figure out, all you need is a volt meter.
Take the Speaker Voltage Test!
Old 5th November 2017, 10:49 AM   #18
cliffforrest is offline cliffforrest  United Kingdom
The UK (230V) has Neutral bonded to earth on the box. There should be no more than mV difference between earth and neutral anywhere in the house. I think this is now the norm in the UK.
If you have ever seen the results of a lighting strike on power cables you would give up pretty quickly on micky-mouse DIY solutions!
Old 6th November 2017, 02:15 AM   #19
PRR's Avatar
......neither leg of 240 is really neutral.
Define "Neutral".
Conceptually, a neutral has no load current.
This actually happens on fully balanced 3-phase loads.
However it is common to find lower-volt loads on one leg of 3-phase to "neutral". Now there is current in Neutral.
The US domestic system is a sub-sub-set of such a system. One phase as two opposite 120V legs supplied from a CT winding. Large loads may be taken off as 240V (and no CT current). Small 120V loads are tapped both 120V legs, and on average "tend to cancel" (no CT current), but never do sum to zero in real life.
So in practice "Neutral" is a word that leads to confusion.
What we may really be asking is: is one of these wires tied to DIRT ?
100 years ago, it was argued that un-grounded systems were safer. Easy to show in the lab. Practical men knew that no real system can be un-grounded; there's always leakage ample to electrocute. Also lightning WILL find dirt, so giving it multiple local dirt-rods tends to localize damage and minimize the extent of blackouts.
"ALL" utility systems are tied to dirt somewhere.
(An interesting exception is inside steel mills, a rare case where grounding clearly increases collateral damage.)
In US household power we about-invariably tie dirt-rods to that CT on the 240V winding. The power company at their transformer, and the house at the service entrance (supposedly).
(However it IS legal to have a sub-circuit which is _120V_CT. The idea is that this reduces the 60Hz field in the room and at your gear. 60VAC each side tends to cancel the electric field around the wires. Legal and should be safe. There is a case where another geek-mod disagreed with 120VCT and caused damage.)
In the UK the domestic power is almost always 240V with one side nominally tied to dirt and the other 240V hot. This is probably supplied from 3-phase Y transformers, houses distributed over the three windings semi-equally. The exact location of the dirt-bond is carefully specified between electric supplier and each unit. My impression is that UK suppliers tend to take responsibility for PE so that individual units do not have to.
However it is NOT technically required that one of your current conductors is tied to dirt. Only that some point in the system is. There are places with 3-phase Y and the CT tied to dirt, but loads fed from 2 of 3 Y-ends. You get 230V load voltage, both legs 132V away from dirt. Lightning will still find its way through the transformer insulation to dirt. No normal load should object to both legs live of dirt or Protective ground/earth. No load should be flowing significant current to PE except in fault. And in this case, the "Neutral" really does run zero-current so can function as PE without conflict.
Someone posited "mV" of N-PE potential. I can (in theory) show 22V of N-G potential worst-case (max load on one 120V leg, no load the other leg). That would be bad but unusual. However you can usually show half of the total line drop. Max line drop can be over 10%, so a 240V system will show 12V N-PE at full current. Less at normal currents. My house shows 1V-3V N-G most of the time. Not a dangerous voltage, but well up from Zero or mV.
Old 7th November 2017, 03:03 AM   #20
Pano's Avatar
Measured at what point in the system? In large show systems we see voltages like that, and more, but it usually leads to noise problems. There's always some neutral current.
Making your own lightning arrestor.Hide this!Advertise here!
Boat making techniques in Speaker Cabinet making.... sansterre Construction Tips 14 28th May 2013 02:03 PM
Lightning music. Helmuth Multi-Way 1 16th September 2011 10:05 PM
Grounding and Lightning jackinnj Everything Else 0 18th October 2004 11:32 AM
Thunder and lightning. In jleaman Everything Else 3 8th July 2003 07:12 AM
Lightning chris ma Everything Else 2 10th May 2003 03:49 PM
