Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Mouse pee smell inside pressboard amp cabinet - How to Remove Odor
Old 22nd October 2017, 01:46 AM   #11
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Never tried the enzimatic one so canīt comment on it, but ammonia and urea in any mammal pee (cat/dog/rodent/human/horse) can be decomposed (so neutralized) with lye.
Yes, this will emit noxious gases.
Problem is a lot of it will also attack presswood/MDF/chipboard so dilute it, from 1:1 to 1:5 in water and spray a little on suspect area, only enough to wet iit, then let it work a couple hours.
Repeat as needed, so you know you applied minimum necessary and no more.
If possible, let the wet area dry in direct sunlight, UV will also help kill odor.
Slow but best results,
After you got rid of 99% smell, mask residual with citric oil as suggested.
Sorry but white vinegar and baking soda will neutralize each other and become inert.
If you hate chlorine smell, peroxide is second best, but nascent oxygen is less aggressive than liberated chlorine.
Donīt think you need to go to such extremes, but if annoyed by residual chlorine smell, (which will evaporate on its own on a couple days) spray slightly afterwards with a weak sodium sulfite solution.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 23rd October 2017, 01:27 AM   #12
Hogwild is offline Hogwild  Canada
An even safer way is to run an ozonator (ozone generating machine) near the object. It does not need to touch the object. The fumes can be dangersous if you get too much of them in your lungs. You and every other being should be somewhere else, and this assumes you're in a house. If you're in an apartment, forget it.
But if you leave an ozonator on for a while, it will kill just about any smell on earth. I've used this several times for my house and it's as close to magic as I've ever seen.
Old 23rd October 2017, 02:15 AM   #13
rif is offline rif  United States
Neither a cowbow nor dog owner
rif's Avatar
Wow, I had no idea ozone was dangerous. My sharper image ionic breeze air cleaner produced ozone, apparently that was a major point in its recall and the downfall of the company.
I always liked the smell of ozone - I associate it with the Lionel trains from my youth. To me it smells clean, antiseptic. Live and learn.
What Happened to Ionic Breeze? - Air Purifier Guide
Old 23rd October 2017, 02:19 AM   #14
JMFahey's Avatar
EDIT POST # 11 ABOVE.
I wrote
lye
, should have written
bleach
instead.
Brainfart
Old 23rd October 2017, 03:45 AM   #15
PRR is offline PRR  United States
PRR's Avatar
I suggest you report Click the image to open in full size. your post and ask a Moderator to change your words in-place, so some hasty reader doesn't lye his floors.
Old 23rd October 2017, 04:33 AM   #16
exurbia is offline exurbia  Australia
exurbia's Avatar
Lighter fluid, don't use a match with it. The aromatics in the fuel kill the smell and evaporate completely. Xylene is even better, but it's quite toxic.
The Commonwealth, going round and round and.....
Mouse pee smell inside pressboard amp cabinet - How to Remove OdorHide this!Advertise here!
what else to tweak when im inside cabinet 02GF74 Multi-Way 2 19th May 2016 06:12 PM
Cabinet inside finish audiostrat Construction Tips 3 15th December 2015 07:40 AM
Speaker wire for inside the cabinet? Kooshball Multi-Way 12 4th March 2013 02:07 PM
does your birch ply cabinet smell like mine? PreSapian Multi-Way 11 11th April 2011 06:50 PM
Soldering Inside A Cabinet DreadPirate Multi-Way 6 5th December 2010 09:21 PM
