Cutting, drilling, mounting etc. for the absolute beginner
Wowser, there was just one reply when I went to bed last night. Thanks to everyone for all your responses relevant and otherwise. I've got two MTB's one's alluminium and the other's crabon fibre, are bikes commom to all audio fanatics?. I believe BMXs are largely steel because of the way steel fails less catastrophically than aluminium. It's also much easier to weld the frame back together after you've wrecked it.
Anyway, I've got some more questions now.
Tapping, is that making a thread for a screw or bolt?
What's a blind hole?
What are plug taps?
Thanks again so much for all your responses. I reckon my first attempt at chain drilling should be a dream after so much advice from the worlds two leading experts :)
What you probably suspected....
Exactly.
A hole that does not pass all the way through a piece of material.
What are plug taps?
Taps designed for finishing off tapping a blind hole. (To get the thread tapped as close to the bottom as possible).
