Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 31st March 2004, 04:21 AM   #1
Default Aluminum Panel finishing - Anodizing
Does anyone know how to prepare aluminum to get the rather "white" look to it when it is anodized?
A friend brought the aluminum boom to his sailboat to a shop to get anodized. He had sanded it. When he got it back, you couldn't tell that anything was done to it (though I believe it was). The sanding scratches were very shiny.
So if anodizing doesn't change the appearance in any way, how does one prepare the metal to get the whitish look that we see so often?
Vince Harris
Old 31st March 2004, 04:44 AM   #2
Magura is offline Magura  Denmark
Magura's Avatar
I believe its called glass ball blasting....like sand blasting, just with tiny glass balls instead.
That leaves you with the silky look.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 31st March 2004, 05:02 AM   #3
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
Yeah, bead blasting. Much nicer than sand blasting IMHO because you get small, evenly sized rounded pits in the metal surface rather than the sharp nicks left by sand grains. Bead blasting gives a very smooth, uniform appearance.
- Chad.
Old 31st March 2004, 06:02 AM   #4
Philo is offline Philo  United States
Glass beads don't have to be the final finish if you want something even finer. There are other materials that a finishing shop can use like poly grit or walnut shells that produce a different finish. Think about using a layered looked (two pieces sandwiched together) with each piece having a different finish.
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 31st March 2004, 09:03 PM   #5
S.C is offline S.C  United States
Send a message via ICQ to S.C Send a message via AIM to S.C
So blasting is the only way to solve the scratch mark prefectly ..etc etc, right? What if I use some power tool to sand it before anodize it (the aluminum plate)? Will I get good result out of it?
Old 31st March 2004, 09:15 PM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The usual finish on stereo equipment is not blasting, but brushing, either on a belt sander or the abrassive wheel.
Old 31st March 2004, 10:44 PM   #7
Peter is correct that the usual way is brushing prior to a anodizing finish, but I (always in a rush) can get a more consistant finish with blasting than with brushing or sanding. Most of the time I get some kind of inconsistancy that bugs me everytime I look at it. To answer your original question... IMO beadblasting leaves a "whiter" looking finish. Experiment and see which one you like. All part of the fun...
Philip
Old 31st March 2004, 11:02 PM   #8
Here's more info on brushing: brushed aluminum finish, how to?
Old 2nd April 2004, 01:32 AM   #9
hifiZen's Avatar
Thanks for the link, Peter - that's some good info.
What do you think about the difference between alodine and anodize finishes in terms of durability (scratch and stain resistance)? ... and have you tried doing any type-II anodizing yourself? It looks to me like anodizing produces a tougher finish, at the loss of electrical conductivity.
Apart from the usual chemical precautions (rubber gloves, face mask/goggles, fume ventilation - the same things apply to alodining, I'm sure), anodizing looks quite simple and perhaps even cheaper than alodine. All it takes is a power supply and some battery acid. Then you have your choice of colours if you want to dye the parts. Or, you can just seal the surface by boiling in water to get a clear finish.
Have a peek at this site for detailed info on anodizing.
- Chad.
Old 2nd April 2004, 01:37 AM   #10
hifiZen's Avatar
Second, I'd love to be able to reproduce a bead-blasted finish at home. I personally prefer a grainless finish which is really uniform and smooth... bright (white-ish), yet fairly matte just like fine bead blasting. Any ideas on how one might accomplish this without paying for a commercial bead-blasting job?
- Chad.
Speaker Finishing - Aluminum Trim Narcisse91 Multi-Way 13 21st March 2007 10:03 PM
Aluminum panel finishing methods ashok Parts 7 2nd June 2006 07:56 AM
anodizing nyman Everything Else 2 8th March 2005 10:51 PM
DIY Anodizing Andrew Steele Everything Else 11 30th May 2002 10:49 PM
Anodizing doktor Everything Else 7 16th April 2001 09:05 PM
Page generated in 0.12263 seconds (80.26% PHP - 19.74% MySQL) with 10 queries
