Is it weird that I use the capacitance tester on my multimeter to check LED's??
to confirm they are working??
because either way I put it around it still lights up! A little bit flickery from the multimeter pulsating the output but it works
it can only measure up to 2000uF though!
Thats fine.
For some reason it takes a while for a "reading" to appear on the capacitance tester.
it stays on utterly 0 for a few whole seconds. then jumps up to the capacitance value suddenly.
Oh yeah also another random thing. my package i ordered says its going to get here today via USPS
but its just stuck at arrived at post office in my town.
Can i go to pick it up or will it eventually start moving and get here?
its about 10 AM where im at right now
Thats fine.
Cool! I wonder why my multimeters diode setting doesnt work for LED's
Maybe it was never intended to test LED's and only meant for regular diodes/transistors????
its NeoTeck brand multimeter
I have an AstroAI AM33D multimeter as well and it has the same problem. No led test ability
although with my AstroAI I can test LED's with the 200 ohm resistance setting (but I dont use this multimeter as much because its not very accurate. its reading a few mv low I think.)
