Hires 96/24 listening test of opamps - Page 4 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
View Poll Results: Which of the files do you prefer by listening?
rr 1 11.11%
ss 1 11.11%
tt 2 22.22%
uu 5 55.56%
vv 0 0%
Voters: 9. You may not vote on this poll
Old 19th June 2017, 02:13 PM   #31
Originally Posted by Jakob2 View Post
But doing an ABX consisting of a small number of trials is only recommended if the listenerīs detection ability is really good, otherwise the risk of commiting a type 2 error gets unbearable.
To small number of trials can get type 1 errors.
To eliminate type 2 errors, just take your time, take pauses, there's no limit on how much time you should spend. And then you can do 20 trials eliminating both type 1 and type 2 errors.
For preference tests with very small differences, like this test, ABC/HR should be used. BS.1116*:*Methods for the subjective assessment of small impairments in audio systems
I don't have to think!
Old 19th June 2017, 03:08 PM   #32
DPH is offline DPH  United States
Originally Posted by PMA View Post
I received preferences of one of our members by PM, which is in almost perfect correlation with parameters of the op amps used. If anyone else has his opinion as well, please do not hesitate to contact me by PM or e-mail.
Isn't this more alarming than encouraging? Anything with that kind of concordance reads more like someone "listened" with their eyes than with ears.
Jacob- I agree, it's a shame there isn't a foobar plug-in for configurable forced choice testing.
Happy DIYing, Daniel
(This space is occupied by the artist formerly known as Derfnofred)
Old 19th June 2017, 03:30 PM   #33
PMA is online now PMA  Europe
PMA's Avatar
I would not say so. IMO it is quite impossible to say anything from file analysis in this current test. And if he really heard what he describes to me in a PM, then hats off. Of course it is just one test set.
Old 19th June 2017, 04:55 PM   #34
Fair enough, Pavel. It's one data point and, well, props if it checks out. I clearly have not looked at the files, for a number of reasons. (Laziness being foremost!)
Old 19th June 2017, 05:08 PM   #35
Mooly's Avatar
I'm more perturbed by the fact that I can't immediately pick what is essentially a 741 from a cluster of better devices. Not quite sure what that is telling me actually......
My current method is to play either the opening or to jump in at a certain point but not to ABX them. I then score them out of 10 giving a middle score of 5 to the first device (simply because it is first in the list) and then marking the others as either same, higher or lower.
When I think I have found a preference for one or more I then put that plus the worst scoring into the ABX procedure and become despondent that the differences melt away.
Old 19th June 2017, 05:46 PM   #36
jcx is offline jcx  United States
Default in AB/X listening test, to me a pairwise comparison is a 'unit'
I mainly listen pairwise in AB/X, A vs B to try to find, fix 'the difference" in my memory then alternate A vs X and X vs B, with A vs B, frequently 'refreshing' listens to A vs B
even when when something seems 'obvious' I test A vs X, B vs X is 'same or different?' rather than just trying X and calling it as A or B
Old 19th June 2017, 06:09 PM   #37
Jakob2 is offline Jakob2  Germany
An experimenter chooses the significance level at which he wanted to test at first and from there he gets the minimum number of trials needed.
Elimination of both error types isnīt possible, just getting both error risks at the same level (presumably).
While accomodation to the test protocol will probably help a lot, without positive controls the experimenter doesnīt know about the risk of commiting an error of the second kind.
He has to assume several detection probabilities and to do a power calculation under these assumptions.
As said before, ABC/HR is a nice protocol but A/B paired preference comparison well planned and executed is another one.
Old 19th June 2017, 06:10 PM   #38
ashok's Avatar
When do we get to know what the chips are ?
I used a Philips SHP8900 headphone via my sound card which is quite decent.
Tomorrow I will try it again using my Beyer DT990. Maybe play the files via my external DAC / headphone amp.
The differences on the SHP8900 aren't huge but some parts seem distinctly different. Will have to do it all over again and see if I have the same ratings I made in the first round on the SHP8900.
AM
Old 19th June 2017, 06:11 PM   #39
Itīs another possibility but no longer an ABX test....
Old 19th June 2017, 06:40 PM   #40
PMA's Avatar
The poll will close on 27th June. It is written in the poll head.
Audio Streamer for 24/192 or 24/96 options barackuda Digital Source 23 3rd December 2016 02:57 AM
DAC to use for 24/96 at most osd1 Digital Line Level 2 17th August 2013 10:57 PM
2x4 in Box with 24/96 or 24/196 aazeez1975 miniDSP 3 8th July 2011 10:40 AM
Are there any DIP 24/96 or 24/192 ADCs and I2P to FireWire Codecs? BoilermakerFan Digital Source 0 21st July 2008 08:27 PM
24/96 and 24/192 is no good. MP3 sounds better! peranders Digital Source 92 30th July 2002 09:30 AM
Copyright Đ1999-2017 diyAudio
