Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 18th March 2004, 11:58 PM   #1
bonsai171's Avatar
Default hum from tv coax
hello, my system has for some reason become sensitive to a hum which is coming from the coax connector which feeds the cable signal to my tv (which is right next to the stereo). I have tried crimping on a new connector, but that didn't make any difference in the amount of hum that was coming through the system. As it turns out, the actual hum is transmitted into the stereo system by a composite video cable running from the tv to dvd player, but if you disconnect the coax connector from the tv and play the dvd, there is absolutely no hum.. How can this situation be fixed??? tia
Dave
Old 19th March 2004, 12:54 AM   #2
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
I had OK results with this situation a few years ago. I used a pair of 300ohm twin lead to 75 ohm F connector baluns wired back to back.
The ground loop went away and the TV still looked OK.
I'm sure there is an isolation transformer made for the purpose, but for 3 bucks, this did the trick.
Old 19th March 2004, 08:33 AM   #3
moamps is offline moamps  Croatia
Capacitor isolation network will work too.
regards
Old 19th March 2004, 08:41 AM   #4
Frank Berry's Avatar
I've tried both methods and found that using capacitors is superior. I got too much loss on the high channels when I used back-to-back transformers.
Frank
Old 19th March 2004, 02:08 PM   #5
Da5id4Vz's Avatar
I'll have to try the cap method.
Old 19th March 2004, 02:27 PM   #6
bonsai171's Avatar
Default clarification
so that's a 10 microfarad and 100 microfarad 200V ceramic capacitor you're using?? How do you actually connect each capacitor? One more thing- what do you do if you lose some channels by doing this? Thanks a bunch.
Dave
Old 19th March 2004, 03:04 PM   #7
values are 10 to 100nF (nano) ceramic.
With 75ohm load those caps make high pass filter witch attenuate ground loop current (50 or 60 Hz). I don't think that you will lose some TV channels (100 to 1000MHz band).
Old 19th March 2004, 03:22 PM   #8
tiroth is offline tiroth  United States
You are luckier than me. I have some 170VDC on my TV "ground" due to leakage in the switching supply. Good reason to use HV rated caps.
Old 22nd March 2004, 03:38 AM   #9
bonsai171's Avatar
Default problem fixed!
moamps,
Thanks for the suggestion. I built one of these isolators yesterday, and it competely eliminated the hum, as well as improved the picture quality on the tv! Cheers!
Dave
Old 26th March 2004, 11:58 AM   #10
Tensop is offline Tensop  Lebanon
hi guys, im having a sort of similar problem. im getting hum from my antenna, enough that it actually heats up the antenna cable. it runs from the antenna, to the VCR, through to my amplifier and to the VIVO port on my computer. when the ground connections from the vcr are removed(RCA shielding on both audio and video outputs) the noise goes away, however there is a disturbance in the picture... its unwatchable. is there any way to link it without getting the noise?
ta
Cheap OB coax? jimluu Full Range 2 31st July 2008 03:43 AM
Coax & DBR Thorsolar Multi-Way 4 14th July 2008 09:33 PM
TOS to SP/DIF coax 123chris Digital Source 18 19th July 2007 04:22 AM
Help with design for EV Pro-12B Coax botrytis Multi-Way 29 9th May 2007 08:40 AM
10" Coax in OB inrank Multi-Way 27 12th September 2006 02:20 PM
Page generated in 0.23785 seconds (36.20% PHP - 63.80% MySQL) with 11 queries
