| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I'm looking to build a rack for my amp, pre-amp, and cd player. Does anyone have any ideas or plans for a good, solid stand?
Thanks, Joe |
#2 |
Back in college I had great results using a combination of cinder blocks and concrete paving stones (of the sort you can buy at any discount store in the garden dept.):
cinder block ........................ cinder block paving stone ........... paving stone cinder block ......................... cinder block (the dots represent thin air... the editor takes out the white space in my ASCII art) Yes, it is the old brick-n-board bookcase idea... just without the planks. Note the gaps between the sides: the "shelves" didn't go all the way across. I just let my relatively light gear straddle the gap. My roommates back in college called it my little shrine to music. Benefits: dirt cheap; pretty dang solid; highly configurable: just restack the blocks Drawbacks: ugly; don't stub your toe on it; got sick of genuflecting to the stereo while changing CDs. Did I mention the quirky aesthetics? (Oh yeah: ugly.
Would a woodchuck bother to chuck MDF? |
#3 |
Location: Where the rain does fall but the trees grow tall
The DIY standing shelves design using threaded rods has always seemed like a very appealing way to go. It can be found at this site:
http://www.tnt-audio.com/ Look for "TNT FleXy Table" under the racks and cabinets section. |
#4 |
Banned
#5 |
No DIY plans but here a couple of resources:
www.onlinemetals.com Sheet, plate round tubing, rectangular tubing, rods in stainless, aluminum, brass, copper etc You can have then cut (rough) to order. www.micromark.com Inexpensive source for small taps, dies and drill. www.boltdepot.com if you need something not found at Home Depot I recently completed a wall hung CD rack that holds about 600 CDs using aluminum angle stock and 1"x2" retangular aluminum tubing. Very light anf rigid. If I didn.t already have an equipment rack online-metals would be a good source for the raw materials. Cutting you own threads is very easy in Al and can make assembly easier sometimes than using nuts, plus it may allow for a nicer look in somecases if you don't have nuts showing. |
#6 |
#7 |
#8 |
Moved from SS, it's a bit more appropriate here.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#9 | |
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#10 |
Very interesting approach with the "x" piece instead of boards.
How are the wood peices joined at the center? |
| Rack Stand Wanted | Dominick22 | Swap Meet | 1 | 12th July 2006 01:01 AM |
| My new hi-fi rack | audioPT | Everything Else | 11 | 4th November 2004 09:46 AM |
| MTM stand mount or floor stand | garfieldcat | Multi-Way | 5 | 7th July 2004 12:45 AM |
| someone to rack a pre amp | JeffEH | Pass Labs | 2 | 16th June 2004 06:57 PM |
| what does PA stand for? | Matttcattt | Multi-Way | 18 | 24th July 2003 12:44 AM |
| Page generated in 0.30911 seconds (30.14% PHP - 69.86% MySQL) with 11 queries |
