| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
i have the student version of matlab. i want to know how to implent them. the equations listed online do not work at all, or the coefficient calculators don't work at all. in anycase any links to matlab code for IIR or FIR filters that is more detailed then
resample(x,1,2) or such. i won't post my code because it would take too long and people here generally don't reply to my posts.
if only it could be used for good, not evil... |
#2 |
Did you install the Signal Processing toolbox? You'll need this, since it contains all the .m files with the dsp commands.
If so, then the MATLAB HelpDesk contains complete descriptions of the commands, with syntax examples and so forth.
- Chad. |
#3 |
actually, no, i meant how would you program in the algorithms, the FIR and IIR equations without using simple 1 line commands. i'd like to have an understanding for the actual DSP moreso then just the usage of it.
right now i'm using the FIR online java calculator, but i don't know how to fix it so i get any type of real response.
#4 |
Hello Chris,
Maybe this doesn't help you with your matlab problem, but if you want to have a "feel" on how a real dsp works with IIR or FIR filter, you could look at Rulph Chassaing's book: Digital Signal Processing with C and the TMS320C30. My book was published in 1992, with ISBN 0-471-55780-3. I bought it at amazon.com. Dunno if there is another updated/revised version. It is a very good book, and it gives you a detailed insight on how real time processing works. The explanation is also very straightforward. As the name of the book implies, it only dealt with Texas Instrument's dsp chips. Regards,
The Great Saiyaman Siapa bertelinga hendaklah ia mendengar... (Mat 13:9) |
#5 |
ok, i'll make it simple:
http://www.dsptutor.freeuk.com/IIRFi...iltDes102.html make a filter with a cutoff of 4khz, sampling rate 22khz. i can't do it. all i get is a gain of 150 and a random cutoff frequency. i tried using 1500hz on the 4000hz max assuming it would be near the right value but it was way off. trying 500hz on the 4000hz scale was about the same, and 3500hz on the 4000hz scale diverged. a and b are defined from the site online: o = length(a); x = 0.*(1 y = 0.*(1 l = length(wavIn); for n = 1:l; %shift in a value for x for m = 1 o-1);x(o-m+1) = x(o-m); end x(1) = wavIn(n); % preform the accumulation h = sum(b.*x) + sum(a.*y); wavOut(n) = h; %shift in a value for y for m = 1 o-1);y(o-m+1) = y(o-m); end y(1) = h; end
#6 |
the oh smiley is : o
the sad smiley is : (
| Matlab | mikeks | Everything Else | 3 | 2nd May 2007 07:30 PM |
| Matlab | eag | The Lounge | 1 | 10th March 2006 04:19 PM |
| Matlab-based triode modelling software | Radames | Tubes / Valves | 1 | 16th September 2005 07:36 PM |
| Matlab or Mathematica -- which is your preference? | rif | Everything Else | 7 | 11th May 2004 05:34 AM |
| Modeling speakers in Matlab? | Serow | Multi-Way | 0 | 7th December 2002 09:22 PM |
| Page generated in 0.24538 seconds (33.85% PHP - 66.15% MySQL) with 10 queries |
