Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Electronic Flue Gas Analyser
Old 24th March 2017, 04:20 PM   #21
Michael 5of9 is offline Michael 5of9  United Kingdom
Michael 5of9's Avatar
Smile Itís Original but Not Antique
Originally Posted by DF96 View Post
What you have sounds quite different from what the original designer has described. Have you bought a cheap clone/fake, or one which has been 'got at' by an incompetent 'repairer'?
Please be reassured this unit came direct from Colwick Instruments Limited; I can say that they did bring out a digital version, thatís all I know regarding other versions.
Kind Regards Michael
Heating & Electrical Engineer
Old 24th March 2017, 07:46 PM   #22
DF96 is offline DF96  England
I am no expert on gas detectors, but I would think that a 'CO detector' which actually uses just a combustible gas detector will not be very accurate in the presence of any unburnt fuel.
Old 25th March 2017, 09:04 AM   #23
Thumbs up A Good Choice FIGARO TGS812 Now Updated to TGS822
This sensor is; please checkout post 11 attachment and for further reading the link in post 1, then go to item 6 or 9.
Old 25th March 2017, 11:27 AM   #24
That datasheet seems to confirm what I thought. It cannot tell the difference between CO and methane. It is less sensitive to methane, but the basic problem still remains. To give a meaningful CO reading you need to be certain that there is only small amounts of other combustible gases present. The conditions which give rise to CO (poor combustion) are likely to cause unburnt fuel to appear in the flue. Perhaps the instrument makes some assumption about conditions in a boiler and gives a CO 'measurement' by actually measuring total combustible gas in the flue? That is, it is actually responding to methane+CO but in this particular application there is a good correlation between these two different gases?
In any case, it cannot measure CO2 with that sensor so it must do it some other way. The designer says it uses a different sensor for CO2. Is that extra sensor missing from your unit?
Old 25th March 2017, 12:53 PM   #25
Ron E is offline Ron E  United States
Ron E's Avatar
It is very common for analyzers to calculate (rather than measure) CO2. They usually do it using an O2 measurement in addition to the CO.
Comparing the New Testo 310 and 320 Combustion Analyzers | Ivy Tools Blog
That old meter is not suitable for anything but a collection of antique instruments. Using it for practical measurements and adjusting furnaces is a bad idea and could result in liability issues.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. óAldous Huxley
Old 25th March 2017, 06:06 PM   #26
I guess you can estimate CO2 by assuming (or measuring) an initial O2 concentration and seeing how much has not been consumed by burning by measuring flue gas O2 (and adjusting for CO) but this would assume that the fuel contains no oxygen. Why do this? Are CO2 sensors difficult to make?
Old 23rd May 2017, 01:23 PM   #27
Andrew engineer is offline Andrew engineer  United Kingdom
Default Anagas information please
Greetings. I have just acquired a non-working Anagas analyser, No 9268. I wonder whether David Cameron (or any other contributor) has by any chance an electronic copy of the user manual and/or service manual. I have only had a brief look at the instrument so far, but my immediate puzzle is how to gain access to the 'works'. The aluminium plate covering them appears to be pop-riveted down on to something. But there must be some other fastener hiding somewhere. Many thanks.
Old 28th May 2017, 09:35 PM   #28
Progress: drilled out previous repairer's pop rivets, and will replace with screws. Insides appear fairly clean and undamaged, except for a little corrosion here and there, mainly on power socket. Removed latter, cleaned and refitted. Secured loose batteries. Now it charges nicely. Pump does not work, despite 10v on motor (with battery on charge). Removed motor end cover exposing worn and corroded commutator but surprisingly un-worn brushes. (See photos.). Plan now to remove armature and skim commutator. Question for D Cameron or anyone else: Is eccentric secured just on a press fit?
Old 11th June 2017, 07:02 AM   #29
Progress again: Eccentric is only a press fit. By clamping eccentric between soft (aluminium) jaws, motor shaft can be pressed or gently tapped out. With commutator skimmed and reassembled, motor works fine now.
Main rotary switch turned roughly and stiffly. Dismantled (carefully spring out 2 plastic hooks to separate body), cleaned and greased (Vaseline) rusty ball and spring detents, reassembled. (Dismantle very carefully, watching for location of components and avoid letting anything fall or leap out of place, otherwise avoidable detective work is required to reposition contacts etc correctly.) Works pleasantly now.
Checking over the circuit boards I avoided disturbing any presets, just measuring resistances between their ends, and between each end and wiper connection, and finding values plausible. Nothing in the electronics seemed to require attention.
Cleaned filter (new cotton wool) and water separator and tried instrument, following instructions for use in manual (kindly made available by Michael 5of9 in early post). At first there was much fairly wild excursion of the meter needle, but after some minutes things settled down somewhat. Sufficiently for roughly measuring the CO2 in my breath as a few %. From information available from various posts it seems that the instruments needs to be kept well exercised to behave stably.
Regarding the question originally posed (how does it work for both CO2 and CO, using only one sensor, as in my instrument also) I speculate that the Pegasus combustible gas sensor works for CO detection by oxidising the CO (catalytically) on a heated surface, and measuring the consequent temperature rise. For CO2 detection, which according to the Anagas manual is achieved by measurement of gas thermal conductivity, the same sensor could perhaps be made to work by only gently heating the surface (insufficiently to stimulate oxidation of combustible gas), in which case the temperature achieved would be limited by the ease of heat transfer from the surface to its surroundings. With a suitable flow regime (low flow speeds, small dimensions) this heat transfer coefficient would vary largely according to gas conductivity, which could therefore be deduced from the temperature of the heated surface.
Many thanks to all who have posted useful information, without which I would have got nowhere with my Anagas instrument.
Next challenge is to achieve DIY calibration (without of course buying special gases). CO2 seems fairly easy in principle, but CO more of a puzzle. I have not yet looked on internet for ideas. Time is always in short supply.
Old 17th June 2017, 12:53 PM   #30
Exclamation Maintenance: Grease and Oil Moving Parts
A high temperature silicone grease is essential because the parts will have ware; https://www.rocol.com/products/high-...ilicone-grease
The pump mechanism a drop of sewing machine oil would be better than engine oil; Buy Sewing Accessories Singer Sewing Machine SUPER Oil and Haberdashery at low cost
It would be good to see some more photos of this pump
Electronic Flue Gas AnalyserHide this!Advertise here!
Gas coupling? Burnedfingers Tubes / Valves 6 4th June 2008 01:44 AM
Visual Analyser, LX.1690 Analyser kit and other MAGICS!!! fotios Software Tools 8 18th March 2008 01:48 AM
Visual Analyser & Nuova Elletronica LX.1690 KIT Oscilloscope + Spectrum Analyser fotios Solid State 25 9th March 2008 07:35 PM
Using Gas Regulators alexmoose Tubes / Valves 8 21st December 2006 06:48 AM
