| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Soldering individual wires to a SSOP SMD
This WAS a PCM2902, I thought Id try out one of these to get the digital signal off the computer. Either way I was only gonna breadboard the 11 other components and then hardwire in the chip. Well the chip won. A 1mm soldering tip and fine fine wire and still not luck, looks like all you can do with these is to use a circuit board. Oh well you cant win them all. On a good note the breadboarded adon to my active xover for adding low freq EQ for my XLS went as good as can be expected.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#2 |
OOOOOOOOOOOOOOOOh pretty!!!
#3 |
Don't be fooled by the boards that he's got, he's still, he's still Jenny from the block!!!
#4 |
This WAS a PCM2902, I thought Id try out one of these to get the digital signal off the computer. Either way I was only gonna breadboard the 11 other components and then hardwire in the chip.<<< It can be done you need to lift alternative pins thus increase the spacing. Do you have any more chips.? I have a few samples i can post on if you want another go,drop me a message. Pete |
#5 |
OK lol ignor the posts from paraleeloogram thats my mate from over here
Ok well at the mo I dont have anymore chips I really got a sample to see how small they actually were. Then I thought I'll give it a go just trying to get one to work. If you dont mind sending me a chip id be greatful for another try. I could just get another sample from TI though, but I dont like asking for more then a few. Send me an email then and we'll talk then. Cheers Matt
#6 |
I also needed two attemps to get the pcm2707 working.
The way I got it working was twisting everyother pin up and everyother pin straight out from the chip. Double pin spacing Just be careful not to break any pins |
#7 |
Yes thats the idea I came to when attempting to solder, thing is that idea came to me after I had soldered a few pins together by mistake. I had to use a scalpal to get them appart, this put unecessary strain ona couple of the pins and one broke off. If you bend the pins up I think they will survive but only if they are left in that position.
#8 |
After the pins have been pulled up, how do you mount the chip? It seems like it would be hard to keep the chip from wiggling inside the finished product and breaking. Some kind of casing to keep everything stable would be cool, but Im not really sure how to go about it.
#9 |
Get two identical chips and on the first one solder to pins 1.3.5. etc. On the second solder to pins 2,4,6, etc. This gives you some room if you don't have the tools to work with sneezed-on components!
Of course I'm just kidding.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#10 |
On the subject of soldering insanely small chips,
When I think a soldering job is becoming a bit tricky, to regain my perspective I regularly return to this thread: Possibly the smallest surface mount chip? Setmenu |
| How much mis-match can an OT take? | bereanbill | Tubes / Valves | 6 | 10th May 2009 01:40 PM |
| How to match tubes? | pftrvlr | Tubes / Valves | 2 | 12th August 2007 08:59 PM |
| To Match Impedance on DI Box, or Not to match? | MisterAlex | Instruments and Amps | 1 | 21st November 2004 10:09 AM |
| How to match MJL3281A? | Calebay | Solid State | 31 | 24th February 2004 09:41 AM |
| How to match the FET | TjongKristian | Pass Labs | 2 | 6th September 2002 05:57 PM |
| Page generated in 0.21678 seconds (45.28% PHP - 54.72% MySQL) with 11 queries |
