Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
music archive, 100 year method
Old 4th December 2016, 10:22 PM   #21
PRR is offline PRR  United States
PRR's Avatar
> is nothing sacred?
> you can't be certain to find SATA hardware in a hundred years...
Indeed, I would be certain you could not.
But interfaces come and go. A viable long-term storage MUST include copying and diffusion. The scrolls in Alexandria were probably re-copied several times over the long history of the library. And as noted, many were copied and the copies carried away throughout the world. When Europe fell into the Dark Ages and old scrolls were fire-starters, fortuitously the Irish had developed a passion for copying old works and saved a lot for posterity.
When SATA replaces PATA, and TATA replaces SATA, and UATA replaces TATA, and sub-space etherics replace all plug interfaces, there is always a few-year window when old and new technologies co-exist. I recently retired (then re-commissioned) my PATA&SATA mobo. It was not long ago I had a SATA card for an ISA mobo. FWIW, 3.5"-flop to USB drives can still be found. By back-compatibility, I would expect to be able to cobble a 5.25" flop to the guts of one (for standard formats, not for odd head/sector tracking).
There are several LONG-running companies who take over abandoned deep mines and become Secure Physical Storage. There's one in the NJ (NY?) hills who runs a courier van into NYC every day to fetch tapes-and-whatever from NYC's mighty data centers. (I'm sure they take FedEx also.) Cool constant temperature, ample physical security both by staffing and by the nature of a deep mine. As long as civilization does not collapse, there is ample incentive to keep these operations going for Big Business, so your little heap will be secure.
Iron Mountain is perhaps the most famous ex-mine storage outfit. I note they maintain separate vault environments for film, tape, paper, and other media. But there are several others, and some may be more open to small less-valuable storage. (Your tunz do not compare to central bank records, or even identity documents like the friends of IM's founder.)
Old 5th December 2016, 01:41 AM   #22
jfetter is offline jfetter  United States
jfetter's Avatar
Due to my failed cache retreval, I have come up with better locations.
Looking at some old USGS maps I noticed a landmark that never moves, cemeteries.
I know of a setteler/pioneer graveyard deep in the back country. Found it when I noticed old wagon ruts barely recessed on the ground.
Checked it later and sure enough was on a survey.
So have the exact coordinates without a gps.
-bruce
Old 5th April 2017, 01:34 AM   #23
jfetter's Avatar
powered up some old laptop drives today, they have been idle a long time, 6-8 years.
it was only an experiment. All were fine.
Im thinking for a real long term recovery, warm up the drive on 180 degree plane from the storage position. then tap gently on side of casting prior to power up.
flash is too risky i think.
Old 7th April 2017, 05:07 PM   #24
DF96 is offline DF96  England
Two options:
1. copy the data about every 10 years to new media; if necessary, recode to new standards too
2. put the data on paper tape - this is not a joke, as we know that paper can last for centuries if kept under reasonable conditions and it should be fairly easy for any level of technology to detect holes in paper. Include on a tape an ASCII description of the digital audio tape format. (Long after magnetic storage became easily available, UK nuclear power stations required that the source of all computer software used in them was stored in a paper tape archive so it could always be read).
Old 12th April 2017, 07:15 AM   #25
Pano is offline Pano  United States
Pano's Avatar
Hmmmm, an audio CD converted to paper tape. How big is that reel going to be?
Take the Speaker Voltage Test!
Old 13th April 2017, 07:50 PM   #26
lcsaszar is offline lcsaszar  Hungary
Use sheet music, become famous and popular, the rest goes by itself. Think of Mozart.
Old 29th April 2017, 04:26 PM   #27
jfetter's Avatar
I actually considered the bar coding method ( from Byte magazine 70s ) but from working at a newspaper I know its impossible to rely on 'paper'.
Its in a constant state of decay.
Powered up another laptop that has been in storage for at least 10 years, I had totally forgotten about it. My wife had put it in her closet.
I removed the l-ion pack and powered it up, no problems.
“A grounded grid is a happy grid”. jfetter
Old 29th April 2017, 05:15 PM   #28
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Seems to me that carved stone has been proven to last thousands of years. Egyptian hieroglyphics etc.
Make three copies of each original (in case the stone fractures due to bad luck, earthquake, etc) and store the copies in geographically separated locations. Done.
Similarly, photographs _can_ last hundreds of years if well-made and well-cared-for. Those photos of Abraham Lincoln are 160 years old.
Old 29th April 2017, 09:02 PM   #29
Good quality paper can last for centuries under the right conditions. Ordinary commercially produced books from a century ago or more are still readable with no difficulty.
Old 1st September 2017, 08:24 PM   #30
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Here is an archive. I bet, still available in good quality!
The Record Collection Once Valued At 50 Million Dollars
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
music archive, 100 year methodHide this!Advertise here!
MarkAudio archive microdub Forum Problems 3 8th April 2015 06:54 AM
Happy New Year..."Happy New Year" to all . Best Wishes and God Bless Albert Walfie Fixer The Lounge 12 1st January 2012 11:02 AM
Baaa...New Year same as the Old Year T in AZ The Lounge 36 7th January 2010 09:06 PM
xp20 year oct 08/xp20 year 2009 GUSTAV1966 Pass Labs 2 12th December 2009 04:26 PM
Archive not accessible ashok Forum Problems 1 22nd May 2004 01:28 PM
