Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 9th March 2004, 07:16 PM   #1
jim is offline jim  Belgium
Default 75 and 50 Ohm cable ?
Hi all,
At work I had a questions about these cables.
How did they come to these values, why 75ohm and 50ohm and not for example 35 ? or 86 ?
Thanks,
Jim
Old 9th March 2004, 09:46 PM   #2
Claude Abraham's Avatar
Default re : 75 & 50 ohm cables
It's been a while, but I remember 75 ohms as being very close to the radiation resistance of a half-wave dipole antenna, which is around 73 ohms. A 75 ohm cable provides a good match with such an antenna. The 50 ohm cable provides lower loss, or less attenuation per unit length. I seem to remember reading that 52 or maybe 53 ohms provides the lowest signal loss. The equations are quite involved. Now, I'm probably going to spend time searching for the details since you've got me wondering. Anyway, off the top of my head, that's what I remember. If I find more details, I'll post them. Best regards.
"We wish to reach the moon, not because it is easy, but because it is hard."
John F. Kennedy, 1917-1963, US President
Old 9th March 2004, 10:56 PM   #3
Claude,
that is interesting. As I understand you say there is actually an
optimal characteristic impedance higher than zero ohms that
gives minimum attenaution. I am not good at transmission line
theory, so forgive some possibly stupod questions. Would this
optimum impedance be the same irrespective of the signal
frequency? Would it depend on the relative ratios between
R, L and C in the cable? I suppose it might be that L /C ratio
can't be choosen arbitrarily, but I also suppose we could get
the same impedance by for instance lowering L and C and
increasing R. Would that make any change to the optimal
Z value?
Old 10th March 2004, 05:47 AM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
The reasons range from attenuation (power loss), to um... I forget. Well there are many good reasons and it's mathematical. I know I have a paper around here somewhere but can't find it amid all my other images. John Stewart of rec.audio.tubes sent the scans FWIW.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 10th March 2004, 10:23 PM   #5
Default 75 / 50 ohm cable info
Actually, I was kinda close, but not quite there. The 75 ohm cable offers the minimum attenuation (some references say it's 70 ohms, others say 77 ohms). A 30 ohm cable offers the greatest current density. The 50 ohm value is a compromise between the two. Also, in WW2, there were antennae having around 50 ohm radiation resistance, making 50 ohm cable a desirable match. Now, if I can only find that book of mine with the equations showing the math. I don't even remember which book has it. Best regards.
Old 10th March 2004, 11:39 PM   #6
Maybe slightly off-topic, but since it is an audio forum, what is
the (supposed) characteristic impedance of phono connectors?
Since some people seem to think impedance matchin matters
also for audio, it would seem sensible to use cables that match
the connectors.
Old 11th March 2004, 08:22 AM   #7
Jax is offline Jax  Sweden
The phono connector impedance is undefined and not a controlled parameter in production.
The characteristic impedance is of little importance at audio frequencies anyway, you have mismatches at the transmitting and receiving end so choosing a correct phono is rather meaningless.
That said, it may be useful to terminate cables at high (>100kHz) frequencies to avoid eventual problems with reflections. Having a zobel network at both the amplifier output and speaker end makes sense.
Jan
Old 11th March 2004, 08:34 AM   #8
Frank Berry's Avatar
The following link answers the 50 ohm/75 ohm question.
http://www.rwonline.com/reference-ro..._1_nov_5.shtml
Happy reading.
Frank
Old 11th March 2004, 08:41 AM   #9
According to normal engineering, yes it shouldn't matter. Since
many people claim different phono connectors sound different
and cables sound different and some even use 50 Ohm termination
it could perhaps matter, assuming this is not all just psychology.
Old 11th March 2004, 09:09 AM   #10
Useful reading:
http://bwcecom.belden.com/college/te.../ciocahalf.htm
A 50 ohm coaxial cable has a characteristic impedance of thousands of ohms at 20 Hz
If there are differencies between different phonos, I would say it's contact resistance, capacitance and dielectric properties that differs.
Jan
Anyone using microphone cable in making their phono cable? rich121 Analog Line Level 8 10th September 2010 12:50 AM
cheap cat5e cable for speaker cable fishline Full Range 6 19th May 2009 07:42 PM
New in package Component Video Cable and Toslink Cable for sale cheap jainbaby Swap Meet 1 30th December 2007 05:18 PM
problems with speaker cable as power cable pjpoes Parts 11 14th January 2007 08:24 PM
microphone cable vs coaxial cable Leolabs Parts 4 31st August 2006 10:24 AM
Page generated in 0.13901 seconds (66.98% PHP - 33.02% MySQL) with 10 queries
