| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
can anyone tell if possible . I am using a car paint on some speaker boxes . better off sticking with auto primer thanks
#2 |
I am no expert on paints - but when I asked a local paint dealer about the same thing he said that I better use auto primer and then auto paint ( these are NC based - nitro cellulose).
As far as the filler is concerned I am not sure . But the local filler we get here cannot be used. I use NC based putty used on cars. It works out well. Can't say if it will last very long. But on some MDF stands I made with NC primer and NC paint , there has been no problem. The stands are about 8 years old . Cheers.
AM |
#3 |
Unless you wood working skills are ouststanding,
you will need to go : Sealer, filler, fine filler, primer, paint, laquer / clearcoat. At the primer stage I think only car primer is appropriate. sreten.
#4 |
Did it Himself
I'm assuming you are talking about MDF here. I'd have to disagree (for the first time!) with you there. I tried car primer on MDF and it just soaked it all up - I used LOADS. MDF primer is better, or you can mix a 50/50 solution of either (I can't remember which) PVA/primer or PVA/water then primer.
#5 |
From the sound of it you used primer at the sealer stage.
So we do not disagree. sreten.
#6 |
Did it Himself
Ahh, when you wrote sealer I assumed you meant to seal the edges, like caulking.
#7 |
yeah it probably should be :
Sanding Filler more sanding sealer (presume could be house paint primer ?) more fine sanding fine filler more fine sanding primer more very fine sanding paint more very very fine sanding (not metallic paints) leveller laquer / clearcoat more very very fine sanding leveller more laquer / clear coat more very very fine sanding leveller more laquer / clear coat more very very fine sanding leveller T cut after a month or so. sreten.
| Taking Paint Off Wood | kvk | Everything Else | 7 | 25th March 2008 12:16 AM |
| Paint steel chassis with the "aluminum paint" used on wire fence? | vax9000 | Tubes / Valves | 2 | 23rd July 2006 02:14 AM |
| using auto paint on boxes | busterno1 | Multi-Way | 5 | 23rd February 2004 04:40 PM |
| Page generated in 0.10067 seconds (74.63% PHP - 25.37% MySQL) with 10 queries |
