Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 5th March 2004, 06:46 PM   #1
boyofwax's Avatar
Default Computer grounding
Hi all ! I experiment a lot with homebuild amplifiers, and use my PC as sound source when doing so. Since my PC is not grounded it gives a lot of hum (50Hz were I live), and puts half of the supply on the case, which I don't like :@ . What can I do besides grounding ? Anybody ever took out the 2 caps (?) to ground ?
When I do ground my PC with a clamp there are spraks, and sometimes I makes the earthleak (?) switch !
Anybody ever fed his PC with a convensional power supply (transformer) ?
Old 6th March 2004, 03:04 PM   #2
djmiddelkoop's Avatar
Don't take out these caps for safety and noise ( CE normering ).
Just use an isolation transformer.
If you don't have, send me a mail.
Dick.
Music is the best F.Z.
Old 6th March 2004, 03:36 PM   #3
w00t is offline w00t  Singapore
Seems like you have got a bad PSU for your computer. Ever thought of changing it?
Old 6th March 2004, 08:49 PM   #4
No, there is nothing wrong with the powersupply.
It's normal that half of the line voltage appears on the case when the earth connection is not made. This is due to internal circuitry, safety and filtering actually. So when a conection is made, sparks could be seen and the earthleak detector could come in. These trigger normally at 30mA here in the Netherlands.
So due to the above hum can be heard when connecting to other equipment.
Either you ground your PC powersupply properly or isolate both equipment with a signal transformer.
Dick.
Old 7th March 2004, 02:37 AM   #5
Dick.
I have opened up a few PC power supplies before and noticed that they are all connected to the circuitry only through the Earthing wire. No other part is in contact with the chassis. AFAIK, there should not be half wave appearing on the chassis.
Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... EchoWars Solid State 37 3rd August 2008 08:50 AM
Grounding Qs TheMG Class D 5 10th March 2008 01:42 AM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
Page generated in 0.81267 seconds (7.94% PHP - 92.06% MySQL) with 10 queries
