| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Is there a schematic that "check" the polarity and if it's not correct don't allow the volt to pass??
I need this for a SMPS.. If i connect erroneously the +/-inverted i'll burn a lot of component... |
#2 |
Banned
yes. a diode.
#3 |
positive input ==> Negative input<== ??? |
#4 |
Banned
you have your source ( power supply) and you circuit you connect to the source. Just build a diode in series with your circuit. A schottky will drop 0,1 or 0,2 Volt and will leave current flow only if connection between circuit and power supply is right direction. Whats the problem?
#5 |
I mean if i connect the CAR BATTERY to SMPS...
If i invert +/- i'll burn the SMPS!! |
#6 |
Banned
and what makes the difference? i canīt see more solutions than diode --> protection against current flow in wrong direction or fuse ---> protection against too much current flowing.
#7 |
Bridge rectifier (mind the two diode drops)
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#8 | |
| Passive phase inversion? | TequilaKez | Parts | 4 | 6th October 2008 01:38 AM |
| Op-amp for signal inversion. | K-amps | Solid State | 10 | 24th November 2006 03:36 PM |
| Digital Data Inversion And Adding Question. | mrfeedback | Digital Source | 11 | 28th May 2003 01:33 PM |
| Polarity Inversion circuit | ashok | Everything Else | 17 | 5th April 2003 11:32 AM |
| Page generated in 0.10009 seconds (60.01% PHP - 39.99% MySQL) with 10 queries |
