choke or joke ? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th April 2016, 05:42 PM   #1
payloadde's Avatar
Default choke or joke ?
I have a couple of little commercial audio transformers which by manufacturer's spec have a single primary winding with sections of 900 turns, 600, 400, 300 and 725 turns;
so I thought 900+600=1500 turns are almost center tap with the rest 400+300+725=1425 just 75 turns short;
that said, I add the 75 turns of wire, connect it to the shorter half and measure inductance before and after to check symmetry;
original primary had 9 Henry, the extended primary (surprise !) - 3 H (minus three !)
now that I don't believe ;-)
first I thought this means over range, but range is 20H;
the new turns follow the orientation of the others and there is no shield;
the negative numbers show up every time the new turns are included in the loop;
I modified four of these transformers and they all show this behavior ...
does anybody know, how these "multi-meters" measure inductance ?
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 16th April 2016, 06:58 PM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I find it hard to believe it can even display a negative inductance, not such a thing in the multimeter world.
So we have either a malfunctioning meter or an impossible riddle.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 16th April 2016, 08:38 PM   #3
interesting meter
Old 16th April 2016, 09:55 PM   #4
bwaslo is offline bwaslo  United States
bwaslo's Avatar
Probably means the inductor is looking capacitive at the test frequency (i.e., test freq is beyond its resonance) If you have a tone gen and a scope best to set up a filter with the inductor in series with a resistor (of maybe 5000 ohms), meas voltage across the resistor.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 17th April 2016, 01:31 AM   #5
Enzo is offline Enzo  United States
Meters get fooled. If I take a resistance reading with some residual voltage in the circuit, it shows a "negative resistance" readings.
Old 17th April 2016, 02:59 AM   #6
TMM is offline TMM  Australia
Send a message via AIM to TMM
bwaslo is right, it's because of parasitic capacitance. The winding capacitance is probably making a resonant circuit at the test frequency so the meter sees an even larger voltage across the DUT than it is supplying, hence the negative value.
Old 17th April 2016, 04:24 PM   #7
payloadde's Avatar
so, if it's excessive capacitance, then the question turns into - why should 75 turns on top of 3000 increase capacitance so much that it fools the meter ?
my sloppy winding technique, turns not strictly side-by-side but sometimes on top of each other ... it is repeatable though ...
Old 17th April 2016, 05:06 PM   #8
DF96 is offline DF96  England
My experience is that when something impossible seems to be happening, it usually turns out that what is actually happening is not what seems to be happening or what the builder intended to happen. It turns out that what is actually happening is possible.
Check, double-check, triple-check your windings and connections. Could stray capacitance be amplified by transformer action? What frequency does the meter use?
Old 17th April 2016, 05:48 PM   #9
could it be you measured two different unconected windings ,so capacitance ?
Old 17th April 2016, 05:50 PM   #10
payloadde's Avatar
Well, I double checked with a simple method, putting 24v 50Hz ac across the primary and measured voltages for each section and tap and got exactly the numbers expected from turns ratios, so I'm pretty shure that windings / orientation are O.K.
Now I hooked up a scope and as soon as the earth wire from the scope is attached, the negative disappears and numbers match expectations; it seems the meter (at least in 20H range) puts out a 555 Hz square wave - possibly constant current - 40mV amplitude when measuring an 8H coil, which drops to 10mV for a 2H - so it seems to do a simple impedance measurement with a square wave...
(In the lower ranges amplitude and frequencies are different)
With the scope attached the negatives are gone but tinkering with the probe on other taps they reappeared - and it seems that something with the signal generator in the meter goes awry: the frequency jumps to 5.5MHz and amplitude is now 2volts - no wonder the ucontroller in the meter gets it all wrong !
Is this a joke?!!! xeclipse Solid State 8 22nd October 2010 10:40 PM
does this look like a joke to you? PreSapian Tubes / Valves 12 10th September 2010 05:14 AM
Joke! GK The Lounge 4 20th August 2007 02:42 PM
A joke? Zombie Tubes / Valves 8 28th April 2004 06:28 AM
A Joke, A Joke!!!!!!! SkinnyBoy The Lounge 2 1st May 2003 04:24 AM
Copyright 1999-2017 diyAudio
