Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th February 2004, 10:39 AM   #1
Circlotron's Avatar
Default 0.001 deg C / watt
I was driving along the freeway the other day at a steady 100 kph in my 1400 kg car for a trip of about 20 km, and seeing it was a hot day just over 40 deg C, before I left home I attached a battery and multimeter to the LM35 temperature sensor that is permanently attached to the engine cooling water outlet that leads to the radiator. I wanted to keep an eye on things and also to see what it would get to on such a hot day.
For most of the way the temp sat on 87 deg +/- 0.5 deg. There was about 20 kilowatts continually being dumped out the radiator to the air.
Where it gets interesting is that the water would not get cooled right down to ambient by the time it exits the bottom of the radiator, but lets be conservative and say it gets down to 60 deg C. That's 20 deg above ambient for 20kW, so we would have a thermal resistance of 0.001 deg per watt. That's some heatsink!
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 16th February 2004, 10:44 AM   #2
Tube_Dude's Avatar
Default Re: 0.001 deg C / watt
Good for a 1 KW "radiator water cooled" class A amplifier!!!
Jorge
Old 16th February 2004, 10:51 AM   #3
rwagter's Avatar
Nice, but the "natural convection" is helped along with:
1.- a fan
2.- carspeed of 100 kph
unless you'd strap the amplifier on top of your car and use it only when driving fast this c/w needs a bigggg fan
Old 16th February 2004, 10:57 AM   #4
UrSv is offline UrSv  Sweden
UrSv's Avatar
And WHO said Class A amps were akward in car audio?
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 16th February 2004, 11:08 AM   #5
Account Disabled
or you can remotely mount your amp in some places with really cold windchill (International Falls, ND). How about -11,000 degrees windchill?
Old 16th February 2004, 11:10 AM   #6
How did you come up with the 20KW figure? Are you sure that's the energy dissipated by the radiotor?
Thijs
Old 16th February 2004, 11:22 AM   #7
rwagter's Avatar
20KW might be conservative.
I have no idea what the effivienty of a car is, but a volkswagen golf 1.6 has a 74KW motor (nice that DIN-standard)
Old 16th February 2004, 11:34 AM   #8
Keep in mind that this is not dissipation but mechanical power on the shaft.
The efficieny of a car's engine is about 20%, so your Golf's power dissipation would come up to 300 kW approx.
Fortunately the engine's full power is only needed on a short term basis (acceleration etc).
Apart from the radiator, some heat is also released by the exhaust and the engine's surface.
Charles
Old 16th February 2004, 11:39 AM   #9
diyAudio Moderator Emeritus
roddyama's Avatar
For a gasoline engine, you can roughly figure 25% efficiency, that's power to the shaft. Approximately, a silmilar amount of power goes through the cooling system. The rest is lost in friction, radiant heat, and heat through the exhaust system.
Rodd Yamashita
Old 16th February 2004, 11:45 AM   #10
rwagter's Avatar
So we can conclude that there is a possibility for an even bigger amp there
First Watt F1 Pcb menekken Pass Labs 20 31st January 2009 04:09 PM
first watt f4 help me!!!! mosfet1 Pass Labs 2 18th May 2008 06:44 AM
First Watt F1 need HELP! Simon CHAN Pass Labs 1 4th December 2006 07:06 AM
First Watt F4 ,F5, F6, F7, F8 ? MikeW Pass Labs 9 9th November 2006 07:16 PM
Page generated in 0.12747 seconds (59.11% PHP - 40.89% MySQL) with 10 queries
