Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 11th February 2004, 02:23 AM   #1
Lightbulb Solid Metal Blocks!
I really like the look of having solid blocks of metal as design/functional elements in an amp, specifically one of Peter Daniel's gainclones, and also his CD transport, with a copper frame.
I recently went though the "Metal" section of my phone book, and out of all the places, only 1 store knew what I was talking about! I was quoted $80 USD for a solid block of copper 4" x 1" x 11". For only 9lbs of metal, this seems extremely high to me!!! I have heard mention of Metal Supermarkets before, but I did not see them listed.
Basically I am looking for a solid copper block to use as a heatsink (as in Peter's monoblock gainclone implementation), and maybe some brass square "logs" (.5" x .5" x 12". How much mass (of copper) would be adequite to cool 2 LM3875TF? Also, where can I get those brass/golden spikes that Peter uses so often as bases in his designs?
I may also be interested in Aluminum blocks; how much do they cost compared to copper? To connect piece of metal together, do I need a welder? Or would I drill holes into both pieces, and screw them togther? What tools would I use for this (drill bits)? An example:
Finally, I would like to thank Peter for all the inspiration he has unknowingly given me, and to all the other people on this forum for all the help they provide Sorry for the long-winded post, but I have been thinking about this stuff for along time!
Old 11th February 2004, 02:31 AM   #2
Send a message via AIM to damonpip
www.onlinemetals.com sells small quantities of metal. Their price for 1" x 4" x 12" is $90.98. I'd guess that you won't find it any cheaper unless you find it at a surplus place.
Old 11th February 2004, 03:06 AM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
IIRC, copper is 3 times the price of aluminum. I pay around CAD $50 for those two blocks of copper in the pic (when paid cash at Metal Supermarket )
The only reasonable way to put it together is by using screws. I'm using #10-32 stainless screws here).
As you see in a picture a piece of copper (1 x 2 x 5) is not really used for cooling, but for distribution of heat to aluminum panels and they take care of heat disippation. This amp, even when pushed, was always only slightly warm (up to 30 deg C, I would think)
Old 11th February 2004, 03:18 AM   #4
elizard is offline elizard  Canada
Send a message via MSN to elizard
1"x4"x12" of aluminum is $22.34 at onlinemetals.com
4 times cheaper
what about the feet peter?
Old 11th February 2004, 03:31 AM   #5
Great information so far! Thanks for the input guys. If anyone has any other ideas/tips for anything related to working with metal, it would be great.
How do I drill holes into metal, that will later accomidate screws? Do I make it threaded somehow?
Old 11th February 2004, 03:36 AM   #6
Yeah, you drill the hole, then you make the thread in there. You use a tap to make the thread. It resembles a screw.
Check your local hardware store for tap and die sets, or individual taps/dies (dies are for making threads on rods for use as screws)
Old 11th February 2004, 03:40 AM   #7
4 times cheaper
Bronze is 10 times more expensive than aluminum, if IIRC?
Don't ask me about the feet. My busines partner gets them somwhere locally, even I don't know were
There is a lot of info on metal working in this thread
Useful tools and techniques
You basically drill holes and tap them later. It is mentioned in the above thread.
Old 11th February 2004, 03:43 AM   #8
i dont' suppose there's a way to obtain these
Old 11th February 2004, 03:43 AM   #9
This thread also has some info on how to work with metal The way to build a chassis
Old 11th February 2004, 03:46 AM   #10
You might consider these Audio Zone propriatory parts But there are many different places selling cones and spikes, percyaudio.com comes to mind.
solid state metal preamp fingerwizards7 Instruments and Amps 34 3rd February 2011 09:02 PM
Metal dome should always go with metal cone? Is this a rule? Jay_WJ Multi-Way 5 5th February 2007 06:53 PM
Metal Oxide vs flamme proof vs metal film ostie01 Parts 28 26th June 2006 06:38 AM
PSU for many amp blocks Specterx Chip Amps 8 7th May 2005 07:39 PM
terminal blocks cowanrg Parts 5 12th August 2003 11:32 PM
Page generated in 0.17214 seconds (53.22% PHP - 46.78% MySQL) with 10 queries
