how do you discharge a capacitor? how do you discharge a capacitor? - diyAudio
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 10th February 2004, 08:50 PM   #1
newbie88 is offline newbie88  United States
Default how do you discharge a capacitor?
As you know I'm a beginner and I want to know how do you discharge the capacitor before working on it? Anyone have any safety tips when upgrading or working with power capacitor?
Do you measure the capacitors on the board with a dvm? and how do you use a resistor to drain the capacitor charge??? I don't want to get SHOCKED!
thanks
Old 11th February 2004, 03:07 PM   #2
Notorious is offline Notorious  Netherlands
Notorious's Avatar
You can use 1k/5w resistor (1 kilo ohm 5watt) I would put longer insulated leads on it so you're sure you won't touch anything accidently. In general, how bigger value in resistance how slower discharge.. Never discharge caps by shorting them.. They hate it... Hope this helps..
You might be a tubeneck if your date says "is that a tube in your pocket, or are you just happy to see me?" And it is a tube...
Old 11th February 2004, 05:16 PM   #3
Pjotr is offline Pjotr
Pjotr's Avatar
I use two 40W / 230V light bulbs in series with 2 Hirshmann “Kleps” safety isolated grabbers mounted on the leads for discharging large caps in tube amps. For discharging PSU caps I leave it connected for more than a minute.
Cheers
Old 11th February 2004, 05:25 PM   #4
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
<Mr. Unsafe> I always let 'em discharge, then short whatever's left.. otherwise... just short 'em.. </Mr. Unsafe>
Safe advice is yes, use a resistor. Pick a resistance such that 5 to 20 time constants pass in say 1 to 15 seconds (depends on how impatient you are ). If you want to discharge in 5 seconds, each T.C. is going to be 1 second... if the cap is 100uF, that's 1sec = R ohms * .0001 farad, uhm R = 1s / .0001F = 10kohm. Power rating adequate for releasing that energy in that time... 100uF at 450V is 10J (E = 1/2 V^2 C ), which is 2W average over 5 seconds. It's an intermittent thing so I wouldn't worry about using too small a resistor here.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 11th February 2004, 05:51 PM   #5
hugobross is offline hugobross  Europe
Lightbulb lightbulb
I always use light bulbs too, they can handle a lot of power and you can see when the cap is almost discharged.
best regards
HB
Old 11th February 2004, 05:57 PM   #6
Pjotr's Avatar
Tim
Hi Tim,
Depends, the resistor needs at least capable of handling the peak current, otherwise there is a risk the connection between the resistor element and the end caps will break. So don’t use film resistors for it. Best is to use a wire wound resistor of 10-20W.
Cheers.
how do you discharge a capacitor?Hide this!Advertise here!
capacitor discharge? epicfabrication Parts 1 25th September 2008 12:12 PM
Rail capacitor discharge circuit rtarbell Solid State 8 9th October 2006 11:51 PM
Delayed capacitor discharge in SMPS Vittorio Power Supplies 21 21st December 2005 04:26 AM
Capacitor discharge thkking Car Audio 16 11th June 2005 07:26 PM
Capacitor discharge-time swede Parts 8 20th September 2003 07:13 PM
Copyright ©1999-2017 diyAudio
