repair NAVMAN USB socket? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd July 2015, 08:24 AM   #1
Default repair NAVMAN USB socket?
A Friend has given me her Navman to repair.
The micro USB socket had come loose and was rattling about inside.
The socket is soldered on with 5 pins and 4pads for the enclosing metal housing.
All the pads and all the pin contacts have pulled the pads off the PCB.
I can see, with high magnification, the broken ends of where most of the pads attach to the ground plane, or to the circuits.
Which pins NEED a connection to allow the Navman to work?
Pin1 is to a big solder pad and may be +ve power IN. @ top of pcb pic
Pin2 looks to be connected to a cap and then more circuit..
Pin3 looks to be connected to a cap and the rest of the circuit.
Pin4 seems to be not connected.
Pin5 looks to be connected to the ground plane.
I am thinking that soldering (and maybe gluing) the metal housing to the back plane for interference suppression, and just soldering a strand of wire from Pin1 to solder pad with cap and a strand of wire from pin5 to solder pad with cap.
Leaving pins2, 3 & 4 unconnected.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd July 2015, 08:29 AM   #2
Enzo is offline Enzo  United States
As far as I know you need four wires. Here is some information on USB wiring
USB pinout diagram @ pinouts.ru
Old 23rd July 2015, 04:40 AM   #3
You'll need to use all the wires for data transfer, here's an image for the 5 pin socket shows what each one is.
Old 23rd July 2015, 06:44 AM   #4
Thanks.
That 5pin looks like the micro USB that has fallen off.
The 3 data pins in the middle are not required.
It just has to work as a GPS when in the car.
Looks like you have confirmed I just need to repair the two power pins, 1 & 5.
regards Andrew T.
USB socket comparison for high quality and high demand audio usage diyinhk Parts 2 12th June 2014 12:53 PM
Will wireless USB hub lower the quality of my USB sound card output? rg12 Digital Source 6 6th January 2011 08:47 PM
USB contact A socket, second source? peranders Parts 5 5th January 2011 07:21 PM
Best Way to cut Supply to USB Socket fmak Digital Line Level 14 23rd September 2009 12:49 AM
Usb speakers to Mini Jack socket shadowplay74 Digital Source 1 15th June 2006 10:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
