Capacitor/resistor value suggestions for dc blocking/high pass filter - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 19th July 2015, 09:00 PM   #1
Smile Capacitor/resistor value suggestions for dc blocking/high pass filter
Hello
I was wondering if anyone is able to suggest appropriate capacitor and resistor values for the construction of a new output stage (DC blocking/high pass filter after DAC) for a cd player going out to a standard line level preamp input?
And also (for an alternate more specific project) appropriate values going out to a 50K ohm preamp input?
Cheers
Old 19th July 2015, 09:48 PM   #2
Michael Bean's Avatar
Every commercial CD player either already has a coupling cap at the output or employs a DC servo to eliminate any DC on the output. Beyond that, for a simple coupling cap application where DC blocking is the only goal, the sky's the limit, use as large value that will physically fit. Most preamp inputs will have at least a 10 kohm impedance, and a corner frequency of around 2 Hz will eliminate any negative frequency or phase response effects. So using 10 kohm and 8 uF will give you a 2 Hz corner frequency.
Mike
Old 20th July 2015, 04:21 PM   #3
Mike
Thanks for the info...
Its getting clearer now!!
You see i had modified a stage in the past with 22k resistors and 3.3uf caps going out to my preamps 50k input, and the volume level/gain in comparison to my other players was significantly less……do corresponding values have such effect on volume?
Old 20th July 2015, 08:25 PM   #4
Andersonix's Avatar
On my Oppo DV-980H DVD player which uses the Cirrus CS4361 DAC, I bypassed the opamp output stage by following the diagram in the datasheet for the CS4361 (fig attached). I used 7.5uF which I had onhand instead of the indicated 3.3uF, and I used 1nF for 'C'.
Old 20th July 2015, 11:03 PM   #5
Like this?
22k in parallel with 50k is a little over 15k total with 3.3uF cap gives a Fc about 3Hz, so you're good to go.
Mike
High pass filter capacitor cobretti Solid State 4 10th January 2012 11:30 PM
Do I really need any DC output capacitor between a DAC chip and the low pass filter ? ygg-it Digital Line Level 3 7th April 2011 12:16 AM
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
DAC DC blocking capacitor macgyver Digital Source 12 11th February 2007 08:37 PM
Blocking capacitor as a high pass filter? NV&H Solid State 4 15th February 2005 06:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
