DIY EPIRB is it possible? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 6th July 2015, 03:13 AM   #1
redrooster's Avatar
Default DIY EPIRB is it possible?
I go gold prospecting into remote areas and I'm wondering if its possible to build my own EPIRB (you just never know when you'll need it?) I lent my old one out and never saw it again. They have a 5w radio @ 406mhz TX and a 0.25w radio TX @ 121.5mhz and a GPS. Would it be feasible to do this? A cheap one goes for $250. I was thinking with the small modules that are available now days I could buy the two separate radio modules, a GPS module,a battery,a plastic case,antenna and a microprocessor.Has anyone ever done this DIY? Its a bit beyond me so Ill need to follow a plan or circuit diagram.
Old 6th July 2015, 11:14 AM   #2
DF96 is offline DF96  England
I would hesitate to trust my life to something which was "a bit beyond me". A quick Google tells me that EPIRB are registered to a vessel, while PLB are registered to a person. My guess is that an EPIRB (and PLB too?) need to be type-approved so DIY is impossible and possibly illegal.
Old 6th July 2015, 03:12 PM   #3
redrooster's Avatar
Oh well it was just a thought.Your right!
Old 6th July 2015, 03:28 PM   #4
jackinnj's Avatar
Buy yourself a Breitling "Emergency" Emergency - Breitling - Instruments for Professionals - Breitling - Instruments for Professionals
A preferential option for the poor, need not imply a preferential option for the state.
Old 8th July 2015, 01:32 AM   #5
tubelab.com's Avatar
DIY is not impossible, but definitely illegal. Someone with the knowledge and RF equipment could DIY this, but type acceptance and FCC certification would be required in the USA, and other certs would be required for other countries.
Even for a one off device that would only be used if your life was in jeopardy, proper RF and digital operation would need to be verified. This means a shielded test environment and some RX and decoding equipment.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
DIY ultrasonic LP cleaner + DIY cleaning fluid experiment : FAIL! SomeJoe Analogue Source 6 17th November 2013 09:58 AM
pre amp suggestions, DIY or Non DIY, Im easy mondogenerator Analog Line Level 5 20th August 2012 05:11 AM
diy disco lights? (based on diy rear projection tv idea) dion_lilley Parts 0 4th July 2007 01:34 PM
Wondering if Upcoming DIY design will work with Tubes? Cheap DIY Kits? demon2091tb Tubes / Valves 28 7th December 2005 05:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
