| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Just about to buy a new DMM to replace my rather crappy current one.
But what kind of accuracy should i be looking for in a DMM? I grasp the 'as great an accuracy as you can afford' concept...but that would mean buying something seriously expensive and most likely comlete overkill. So what would do fine for amp building? Cheers, WB |
#2 |
The most precise component you have in circuit might be 1 or 5% (being the resistors), and I imagine most DMMs are at least that precise, so don't worry about it. It is a poorly designed circuit to need even that much precision anyway!
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 | |
I disagree with the previous post - the accuracy of the meter you buy should depend wholy on your intended purpose. The tolerance rating of a resistor only tells how far it will deviate from it's rating and not dictate how accurately you want to measure the voltage across or current passing through it. You should ask yourself the question, "what is the allowable tolerance of any readings I will make?" - if you are working in a medical or military field then a DMM may have to be incredibly accurate (and high tolerance) for it's intended purpose, if you are only making simple circuit measurements on audio equipment then obviously lower accuracy and lower tolerances are acceptable.
...if it ain't broke don't fix it - make it BETTER! |
#5 |
You have to consider what you're using it for. Also, it's important to distinguish between precision and accuracy. Normally, precision is more important.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 |
Although a good precision, good accuray DMM might occsionally
be useful, you may find it better to buy two chepaer DMMs instead, since that allows you to keep track of two parameters simultaneously. |
#7 |
Just make sure its able to measure true RMS, it comes in handy when working on power supplies.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#8 | |
a scope, perhaps, but if you cannot see the waveform anyway... |
#9 |
I agree - often true RMS can be calculated with the appropriate correction factor.
#10 | |
True, but RMS measuring ability dosnt have to make the DMM more expensive, its just nice to have, hence the advice. Magura
| accuracy of ohms law | Clipped | Car Audio | 12 | 27th March 2008 12:36 PM |
| LM317/LM337 accuracy | Stuey | Power Supplies | 6 | 25th May 2007 08:31 AM |
| Phase Accuracy | lumanauw | Solid State | 131 | 1st November 2005 12:56 AM |
| Accuracy and Jitter | CJAVIER | Digital Source | 2 | 16th March 2004 01:12 PM |
| Page generated in 0.13532 seconds (63.25% PHP - 36.75% MySQL) with 11 queries |
