Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 25th January 2004, 02:01 AM   #1
angel is offline angel  Norway
Default Sensitivity to crossover distortion
Has anyone here got information on what frequency segments appear to suffer the most/least from crossover distortion and/or magnetic hysteresis distortion?
It would be interesting to know, in these biamped days.
Old 25th January 2004, 03:20 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Uh.. it's an odd harmonic distortion, so anything below 20/3 = about 7kHz should sound different when distorted as such.
It's far easier to see on the scope than to hear it, I think. Haven't played around with it much.
Lemme see... I don't have 7 12AT7s up here to plug into Hept'AU7 so I'll try Frankenhouse... goes down to... -35V on 6V6s at 350Vs, which is 14mA at the cathode. Sounds just the same, so it's still not even into class B yet. I have -56V available so I can try more bias and get back to 'ya. But right now I have to use the bathroom
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 25th January 2004, 07:01 PM   #3
Yes. And even 7kHz would probably cause phenomenon related to spatial clues. I'm just wondering what ranges are most sensitive.
I suspect as much, as I have a class B amplifier here which has no noticeable harshness or artifacts to its sound. It does lack detail, though, and I expect that can be attributed to crossover distortion.
That would be nice.
Old 26th January 2004, 02:33 AM   #4
Sch3mat1c's Avatar
...After some calculations and poking in a hot chassis it seems the bias supply is 138kohms impedance (that is, it acts as a -500V voltage source with 138k source impedance in series), so only gained but 2V when I shorted the top resistor (4.7k.. below it is 2x10k bias pots in parallel, followed by another 4.7k, then ground). Seems 6V6s don't lose much Gm despite being biased at 15mA! Although, it does have an NFB loop which is going to hide the nasties, as it's supposed to.
I could bring it to the bench and do some more exhaustive studies but I can't help you with audiophilogical persuits, as everyone has their own take on it.
Tim
Crossover distortion - be gone! Circlotron Solid State 4 24th August 2009 12:09 PM
Help New TAC US 12A crossover distortion. spirod Solid State 1 9th February 2008 03:34 PM
Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? rhythmdiy Multi-Way 5 5th November 2007 11:33 AM
Crossover distortion lumanauw Solid State 100 14th January 2005 12:58 AM
Crossover Distortion? Killjoy99 Multi-Way 8 30th March 2004 05:10 AM
Page generated in 0.23149 seconds (34.86% PHP - 65.14% MySQL) with 10 queries
