| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
diyAudio Moderator Emeritus
Hi Everyone,
I notice that in this diyaudio.com, there are many who use simulator/spice to simulate the circuit, before they make a prototype. It seems it can be used for displaying S/N ratio, THD, Distortion curve (even independently 2nd, 3rd order etc), TIM, frequency response, DC offset, possibility of oscilation, etc. I want to be able to use this simulator. Maybe there are many kind of spice out there. What is the suitable spice for me, since I'm a beginner. Where can I find them? Thank you |
#3 | |
![]() I second the opinion. Free, works well, GUI obviously designed by a programmer who understands that a program shuold be easy to use, rather than look like a fancy Christmas tree. Besides, a lot of people on the forum use it, so it is easy to get support here. |
#4 |
Christer,
Can this LTspice displays the distortion curves (every order independently), or can it display the items in my first question? |
#5 | |
has. However, of those things you listed, I would say you can do everything that any other Spice implementation can do, except noise simulation. Also LTspice lacks the built-in distorion analysis of Spice, but I think nobody uses that anyway since it is only a small-signal approximation AFAIK. It seems we all do distorsion analysis by doing lenthy transient analysis and then run an FFT on that to get a spectrum graph. Most of the things you listed can be done in Spice, but not all of them automatically, so to speak. DC offset is easy, you get that automatically from a DC operation point analysis, for instance. OTOH there is no command to ask for stability analysis. You must know how to do a correct open- loop analysis and how to interpret it, but that is not particular to LTSPice. To see an example of distorsion graphs, you may have a look for instance at the thread on "Diamond buffers w. CFP outputs" that we started yesterday. Just remember, a simulation is a simulation, not a real circuit. No simulation is better than the simulator, than its models or than the person using it. Happy Spice-ing |
#6 |
Also some people in this forum use Circuitmaker (including me). A free student version with some limitations, most notably max 50 components in a circuit and a limited component library, can be found here: http://www.microcode.com/downloads/student.htm
Steven |
| Spice simulator engines | rtarbell | The Lounge | 1 | 26th July 2007 12:17 PM |
| Free Spice Or Cheap Spice Simulator-Where To Start? | kelticwizard | Everything Else | 29 | 15th February 2007 02:38 AM |
| Free SPICE simulator.. | tschrama | Everything Else | 25 | 1st July 2002 11:14 PM |
| Page generated in 0.08300 seconds (77.86% PHP - 22.14% MySQL) with 10 queries |
