Consumer grade JBL's + 300 w/ch amp = Disaster? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 17th November 2014, 07:27 PM   #1
Default Consumer grade JBL's + 300 w/ch amp = Disaster?
Speakers - JBL S312 SII:
http://www.jbl.com/resources/Brands/...312II%20ts.pdf
Amp - Behringer nu3000dsp:
Behringer iNuke NU3000 Measurements
Not my gear. This will be used at maximum output for hours at a time in a basement party room. Will be setup this weekend. Thoughts?
Old 17th November 2014, 10:01 PM   #2
sreten is online now sreten  United Kingdom
It can be used at healthy output for hours at a time.
Drunken attempts at running it as loud as
possible for hours will always end in tears.
Setting it to max volume is simply turning it up
and backing it off at the first signs of audible
compression from the speakers, needless to say
this should be done sober, and then things should
be arranged such that it can be turned up no further.
If its not loud enough bite the bullet and use PA speakers.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 17th November 2014, 10:12 PM   #3
Rundmaus's Avatar
Follow the 'setting max volume' procedure described by sreten. And make really sure that it is impossible to turn the volume higher than that.
A lot of speakers are killed by DC from a clipping amp. With the above amp, you should be far from clipping.
Another way of killing speakers is by mechanical or thermal overload. Audible compression and/or distortion effects indicate overload conditions.
Rundmaus
Old 17th November 2014, 10:15 PM   #4
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Agre and add: you might fuse the speaker leads.
A 5A standard (fast blow) speaker allows 200W RMS into an 8 ohm speaker and *should* be safe.
By the way, music program at that level is quite distorted.
Worst case, having one of them popping and muting a speaker during the party is a strong indication of unsafe levels.
You just replace the fuse and go on, at a slightly reduced volume.
Better than the speaker "muting" on its own ... irreversibly.
Old 17th November 2014, 10:18 PM   #5
Thanks guys!
I have limiters available in the DSP of the amp, and know how to use them. Any opinions on where they should be set?
Old 18th November 2014, 03:11 PM   #6
A clipping amp does not produce DC.
Clipping amps produce high levels of odd harmonics which were not present in the original signal thus frying tweeters.
If the amp were to produce DC it could not possibly kill tweeters since there will always (at least with passive speakers) be a capacitor in line with the tweeter whose impedance at DC is infinite.
Old 18th November 2014, 03:45 PM   #7
east electronics's Avatar
well ..id say limit them to 100W rms allow some room for a bit of overdrive .....
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 18th November 2014, 07:38 PM   #8
Rundmaus's Avatar
Sorry for my unprecise language. Of course you are right, but I am not wrong nevertheless: Assuming a DC coupled output stage, as long as the clipping condition persists within a signal peak, the output signal is the corresponding rail voltage = DC. If we are seriously deep in clipping condition, the output will quickly change to the opposite rail when the signal zero crosses.
So the output of a really heavy clipping amp will resemble a square wave, with all these nasty harmonics killing tweeters. (And the square wave consists of many many small regions where the output is DC )
Rundmaus
Old 19th November 2014, 10:14 AM   #9
No DC, just lots of odd order harmonics which are sines.
Like this:http://upload.wikimedia.org/wikipedi...SquareWave.gif
(the red one is an idealised square which require unlimited bandwidth so it will never occur in reality)
Old 19th November 2014, 04:29 PM   #10
Agree that it will be hard to produce real clipping with this amp, with the limiter set it should avoid that. It might have some sort of soft clipping feature? Regardless I have seen them ride the limiter on it with their previous speakers.
Highpass will be set to avoid bottoming out the woofer below tuning. However, without having any xmax specs for the woofer or other parameters, it's impossible to tell if it will bottom the woofer above port tuning...? But highly unlikely. I'd say it's more likely to thermally damage them, or overpower the tweeters or mids somehow....?
JBL 2453 as centre ch. driver? Dave Zan Multi-Way 23 26th September 2013 10:57 AM
JBL SA600 & SA660 integrated 2 ch amps basenjifan Analogue Source 6 2nd January 2012 05:52 PM
JBL 300.4 amp upgrade/mods ahmisuhairi Car Audio 6 26th September 2007 07:34 AM
Broken JBL 300.1 Amp. Help plz! Crustanthrope Car Audio 3 10th May 2005 11:02 PM
FS: pair of JBL 2225H 15" $300 spitz Swap Meet 0 16th June 2004 06:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
