| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
Inrush current will typically always be in the 100 amps or more for a good amp. This is not the way to rate your filters ...
Thermistors work great unless you turn off, then almost immediately on, when the thermistors are still hot (but then you would still have some charge on your caps. Petter |
#12 |
Use thermistors!
#13 |
Is there a way to choose a thermistor for a given toroid power rating ? I asked once a toroid constructor but he told me they choose it by practice.
#14 |
I'm curious to know what ratings to choose for a thermistor given a certain transformer size also...
#15 |
Thermistors are the el-cheapo way out. BAT VK60 has 5 ohm version for 110V and 10 ohm version for 220V -- they come in various sizes and get very hot. Why el-cheapo? Because you always have an extra pass element with finite resistance and you also have heat generation, might not work right if power fails, you don't know if it is broken or not (high temp usually means shorter life).
Check out the size on http://www.balanced.com ... compare with Plitron units at http://www.plitron.com. However, it will vary with type of rectification/filtering and output voltage. You can buy a resistive kit from http://www.lcaudio.com/tilb.htm -- 330 ohms for 3 seconds, probably OK with half the resistance for US. Nice, I might just get a couple but they are not free. Petter |
#16 |
I still think the easiest way to keep inrush current low on turn on is with in series resistors with a timer relay. There are circuits without transformet or power supply direkt from the mains supply.
#17 |
The easisest and cheapest is thermistor -- a series element, hooks up like a resistor, looks like a ceramic capacitor and does not overheat which a resistor could likely do.
It is not the best, though. |
| Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? | bembel | Tubes / Valves | 12 | 11th March 2010 05:56 AM |
| "A standard CD player outputs signal at 24V" | wwenze | Digital Source | 16 | 13th July 2009 04:50 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 08:31 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| cheap 6" or 8" woofer to make great bass for a standard cab pick up | zuki | Subwoofers | 12 | 15th February 2005 07:54 AM |
| Page generated in 0.13736 seconds (58.46% PHP - 41.54% MySQL) with 10 queries |
