Hi there Audio Gurus,
I have a Drok Mini 5V Amp that I'm trying to hookup to a project radio I'm working on. That seems simple enough. the Drok Potentionmeter has the ability to turn on and off the unit. I have a few questions regarding the utility of it.
1) It has 1 left, 1 Ground and 1 Right. Do I solder both Ground wires (the one from the left and the one from the right wire) to the 1 Ground hole on this board?
2) I have a 5v Bluetooth Receiver that I will adapt to this unit via a GroundLoop Isolator. Therefore, I want to share the power furnished to the Amp with the bluetooth Receiver. Here's my question, the Amp right now as mentioned before, turns on and off via the Potentionmeter. How can I extend that function to the bluetooth receiver so that everythign turns off and on via the potentionmeter on the amp?
3) Lastly, I want to adapt a warm light LED to the unit. where would this little guy go?
Hopefully I'm going the right direction, what I want is a final unit with a POT that controls volume and turns on and off that I can adapt to the vintage radio chassis I have and has Aux In and Bluetooth Capability and have a Warm LED Light that replicates the tube Lightning that emits through the Radio AM dial area.
Thanks,
The amps and the bluetooth receiver I'm using are below;
http://www.amazon.com/Logitech-980-...0&sr=1-1&keywords=bluetooth+receiver+logitech
http://www.amazon.com/dp/B00C4N410G...UTF8&colid=ZF0TIU0HMOX3&coliid=I3AUSDLLBABPSE
Thanks,
