Diy microphone blimp question - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th September 2014, 02:19 PM   #1
Default Diy microphone blimp question
Does anyone have experience of mic blimps either diy or ready made versions?
I need to make one to house an Audio Technica AT835B shotgun mic and as always the internet has conflicting opinions about the materials to use.
A common theme is to use a wire mesh bird feeder or waste bin to form the tubular section of the blimp. Others say that no metal should be used as it can interfere with the operation of the microphone and plastic should be used instead.
What are your opinions on this considering the microphone has a metal housing?
John
Old 16th September 2014, 12:16 AM   #2
Enzo is offline Enzo  United States
I seem to be ignorant of this.
Is this UK slang or an official term? To me a blimp is a helium filled gas bag aircraft. And a microphone at 3000 feet altitude doesn;t come up often in ym experience.
What is a mic blimp?
Old 16th September 2014, 12:29 AM   #3
Hi Enzo.
Sorry I should have explained more clearly.
A blimp is the wind proof torpedo or zeppelin shaped microphone housing you see on boom microphones used for outside broadcast or recording. Often they have a fuzzy grey cover over them known as a "dead cat" or "dead wombat" for a large one.
This is a Rode blimp RØDE Microphones - Blimp and costs around £130 hence my desire to make my own.
John
Old 16th September 2014, 04:15 AM   #4
OK. I left the road a long time ago, but in my day we just called such things wind balls or wind covers.
COnsidering the one you linked has metal in the audio path, I don;t know that I;d agree with the metal opposers.
Old 16th September 2014, 04:36 AM   #5
Vasquo is offline Vasquo  United States
Windscreens - another name for them.
I think the metal housing is for the physical protection of the expensive mic from getting bumped against walls, overhead fans, lights, etc.
I don't see how another metal cage can interfere with the mic's electrical operation. The condenser is already protected inside by it's own mesh housing. Plastic is just "cheaper" to manufacture... probably easier to break too. A metal wire will be physically stronger than a thick plastic part, and less likely to interfere with the mic's cardioid pattern.
Old 16th September 2014, 06:25 AM   #6
Pano is offline Pano  United States
Pano's Avatar
I'm building one with plastic mesh. But it was hard to find the plastic with a large percentage of open area. Metal is easier for that. I remember the Sennheiser blimps at work were mostly plastic. For weight, most likely.
Will you be doing the dead cat over it?
Take the Speaker Voltage Test!
Old 16th September 2014, 09:54 AM   #7
Hi All.
I have found a genuine Rode dead wombat on a website at good money, if it stays low I will be buying that for it. That way I only have the body to deal with and a fixed dimension to work to rather than ending up with something bigger than it needs to be. The UK weather being what it is wind and rain protection are essential for a lot of the time.
It seems the diy fur of choice for the dead cat is this stuff Super Luxury Faux Fur Fabric Material - LONG PILE PURPLE & BLACK | eBay but maybe not in dayglow pink. And I was thinking of using this as the mesh Gutter-Clear Mesh 5m x 110mm | Plastic Guttering Accessories | Screwfix.com Have you come up with anything to attach the removable end cap?
I couldn't see how a screened mic could be affected by a small amount of metal near it but thought it better to check before wasting any time on a false start to the project.
John
Last edited by john blackburn; 16th September 2014 at 10:09 AM. Reason: Spelliing mistake
DIY ribbon microphone preamp question efabric Instruments and Amps 2 14th June 2012 09:30 AM
DIY microphone project Rullknufs Instruments and Amps 20 10th September 2011 10:40 PM
Help with DIY microphone please internecine Everything Else 13 24th August 2007 11:26 PM
DIY microphone 454Casull Parts 5 24th November 2006 06:25 AM
DIY : Wireless Microphone . darkm4n Instruments and Amps 7 21st December 2004 05:17 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
