AC electrical leakage from Surface Pro 3! - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 5th September 2014, 08:16 AM   #1
Default AC electrical leakage from Surface Pro 3!
When the power cable is connected, AC current flowing from the power brick on surface pro 3 will cause electrical leakage.
The voltage here is 240V, enough to kill you.
The orange light from the test pen shows AC current flowing through the whole case!
The power brick has 3 pins plug, but the cord is only 2 pins, that means there is no earth wire into the surface pro 3 power cable. M$ should have made a earth wire into the power brick and grounding the metal chassis.
RMA is useless since a replacement adapter will still have such leakage problem.
Old 5th September 2014, 08:22 AM   #2
Kiriakos's Avatar
Just replace the cord then ... problem solved.
If not?
Feel free to trash your cheap PSU of 5$ with free shipping.
Old 5th September 2014, 10:24 AM   #3
DF96 is offline DF96  England
What is the impedance of this voltage source? I suspect you are seeing a little leakage current through a mains filter capacitor. At worst you might get a little tingle.
Voltage does not kill; current kills.
However, it is possible that your PSU is faulty so get it checked by someone who understands electricity.
Old 5th September 2014, 02:20 PM   #4
Speedskater's Avatar
Is that a non-contact voltage probe?
Kevin
Old 5th September 2014, 03:58 PM   #5
Looks like a neon screwdriver, or possibly the modern hi-tech variant with a chip and an LED.
Old 5th September 2014, 04:24 PM   #6
Enzo is offline Enzo  United States
And when you leave it plugged in but turn off the device, does it still glow?
Help with AC electrical wiring in plinth tromba Analogue Source 6 1st February 2013 07:20 PM
~20V AC threw ~100V AC to 12 V AC abcdmku Power Supplies 9 13th January 2013 03:04 PM
Help Me Build My Speaker - (based off Pro Ac Studio 100) deckerluke Multi-Way 1 20th July 2009 02:16 PM
troubleshooting case AC leakage pukka Everything Else 3 7th June 2002 08:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
