Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th January 2004, 04:46 AM   #1
Default Ripping Analog Tapes?
Any good freeware software out there to make wav files from my sound card's line-in?
I have some multi-track recordings I want to get onto CD.
Old 15th January 2004, 04:58 AM   #2
JOE DIRT®'s Avatar
win amp
Old 15th January 2004, 05:05 AM   #3
I have winamp but I don't see a recording option.
Old 15th January 2004, 05:09 AM   #4
JOE DIRT®'s Avatar
Excuse me as I just blurted out that reply....I saw quite a few converters at www.download.com awhile back as well as few other sites
Old 17th January 2004, 04:10 PM   #5
Cool Edit is also a winner. I use it for ripping my vinyl and editing loops etc.
Old 18th January 2004, 03:31 PM   #6
mcs is offline mcs  Denmark
Isn't there something included in what ever OS you use? If you just want to record to .wav files, whatever standard recording utility you have should work...
Best regards,
Mikkel C. Simonsen
Old 19th January 2004, 07:33 AM   #7
B.VDBOS is offline B.VDBOS  New Zealand
B.VDBOS's Avatar
Try Goldwave
http://www.goldwave.com/
Old 19th January 2004, 12:47 PM   #8
If you have Windows, Sound Recorder will do a cheap & cheerful job of recording to a .WAV file. On my Win2K box, it's under Start->Programs->Accessories->Entertainment, or you could search for sndrec32.exe.
On Linux, your very simplest option is probably dd'ing from /dev/audio to a raw file, then using something like SoX (e.g. http://sourceforge.net/projects/sox/) to convert the result to a WAV.
For simple WAV editing I generally use SoundForge, which came free with my sound card, but other folks I know use CoolEdit to good effect.
Cheers
IH
Old 20th January 2004, 08:47 PM   #9
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
A little off topic
I had someone approach me a while back for a proposal to convert a warehouse of 1/4" 7 1/2 IPS tapes to MP-3's.
In order to do the work efficiently I proposed capturing the tapes played back at 15 IPS while sampling at 96 KHz. I figured I could get the FHG software jeeped (a little research made this look very likely) to take these non standard samples and convert them to play back at 48 KHz.
I figured I wouldn’t have too much trouble EQ-ing and setting up the tape machine to give me accurate playback at 2x speed.
A lot of the tape was suffering from sticktion and needed to be treated in a convection oven before transfer. I was never comfortable with handling someone elses irreplaceable archives that needed this kind of work, but I figured with good definitions for methods and procedures we would be able to train operators to be vigilalent.
Well, like many a proposal that I’ve worked on, the company I was working for didn’t get the contract and has since gone away.
It was however a fun one to work on.
Old 23rd January 2004, 03:28 AM   #10
This one is just great. Freeware.
www.dbpoweramp.com
Use the Auxiliary Input. Really nice.
Site has lots of other good stuff too. But this is real easy. A friend has a lot of cassette tapes which needed to turn into CD's. I showed him this and it worked like a charm.
Oops, looks like the site is down, at least for now. Let me check something and get back to you.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
audio tapes to cd chakravarthy76 Introductions 1 8th March 2009 04:21 PM
dcc tapes adason Swap Meet 0 23rd November 2008 11:06 PM
Box of 94 blank cassette tapes Glowbug Swap Meet 1 25th December 2006 08:54 AM
test calibraton tapes pazh Analogue Source 25 20th June 2005 02:35 AM
MP3 from Old Tapes r_s_dhar Digital Source 3 3rd October 2002 09:09 AM
Page generated in 0.26152 seconds (29.42% PHP - 70.58% MySQL) with 10 queries
