Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th January 2004, 04:42 PM   #1
kinser is offline kinser  Israel
kinser's Avatar
Send a message via ICQ to kinser Send a message via MSN to kinser
Default fan
Hi
I have a computer fan that I want to use for my amps heatsink
the prombel:
my power supply output is 30 volts DC, how do I get 12 volts DC for the fan from 30 volts?
thanks kinser
Old 13th January 2004, 06:46 PM   #2
A 78 series 1 amp 12V voltage regulator will do the job. Download the data-sheet for specs and application notes.
Old 13th January 2004, 07:12 PM   #3
joensd is offline joensd  Germany
As fans increase the efficiency of the heatsink substantially it would be probably enough to supply 6-9V to the fan.
Youīll get much lower noise as well of course and the fan draws less current.
Watch the power dissipation of the 78xx-regulator.
Probably around 2W or so.
If you donīt have a class a amplifier you could also think about a temperature-control for your fan which only kicks in when itīs needed.
Cheers
Jens
Old 13th January 2004, 07:23 PM   #4
Account Disabled
I used a lm simple switching regulator (I think it is 2596) for my fans. It runs very cool (>90% efficiency) and needs 5 parts (including the regulator itself). Highly recommended.
You can put multiple fans in series (2 or 3 of them in your case) or to use a power resistor if your fan doesn't draw too much current.
Old 13th January 2004, 10:12 PM   #5
the solution with a switcher would be the most elegant of course
but the main supply will also "see" the switching peaks as well!?
never tried and listened if itīs a substantial noise thatīs created but an amplifier with poor PSRR probably wonīt like it (or better your ears)
Old 26th April 2004, 06:49 PM   #6
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
Have +/- 63V rails... how can I get 5V for a fan?
Old 27th April 2004, 10:09 AM   #7
Found the answer: locate an old (mobile phone charger?) 5V gizmo, hack it, and you have your 5VDC source.
Page generated in 0.10810 seconds (61.09% PHP - 38.91% MySQL) with 9 queries
Copyright Đ1999-2012 diyAudio
