resistor? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th July 2014, 10:08 AM   #1
s214519 is offline s214519  United States
Default resistor?
I wasn't sure what category to put this under so I just decided to put it here. I'm a beginner so I really don't know much.
I was wondering if you change the wattage of a resistor will make a big difference or if it's just the peak. For example; if a resistor says 8 ohms 20 watts, could you use one rated at 30 watts and get the same result?
As I said before, I'm a beginner and am just trying to learn more. So please at least try not to call me dumb. :P
Thanks for any help.
Old 13th July 2014, 10:12 AM   #2
Send a message via Skype™ to JonSnell Electronic
Yes you can always go higher in wattage, space permitting. If you go lower, there could be issues with overload and burn up of the resistor.
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old 13th July 2014, 10:13 AM   #3
That's what I thought. Thank you so much!
Old 13th July 2014, 10:31 AM   #4
I have another question.
In building a power supply, after my transformer I should have 12vac 3 amps. For my bridge rectifier, do I have to get rectifier diodes rated at 12v or can I go higher?
Old 13th July 2014, 10:42 AM   #5
Take a look at some datasheets for these components. Google it.
Ratings such as wattage, or voltage are MAXIMUMS, at which the component starts to suffer or even gets destroyed.
So using a 4 watt resistor where only a 100mW is ever being dissipated will do no harm, but is very wasteful of space and maybe money! But it will not get warm
For cheap-and-cheerful voltage rectification I use only 1N4007 diodes. These are 1amp max and 1,000V max. Some parts from the same family are rated at a lower voltage, but are only fractions of a penny cheaper, so it is not worth stocking more than one part.
Always search for and study datasheets of components. It will help you learn and should prompt lots of questions!
Cliff
Old 13th July 2014, 10:52 AM   #6
SY's Avatar
Generally, diodes with higher voltage and current ratings than needed cost no more, so no need to try to see how close to the needed ratings you can go. The actual minimum will depend on the power supply topology you're using. But in this case, you can get a 100V 10A bridge (4 rectifiers in a single package) for about $1, so why not?
You might be screaming "No, no, no" and all they hear is "Who wants cake?" Let me tell you something: They all do. They all want cake.- Wilford Brimley
Old 13th July 2014, 11:30 AM   #7
jan.didden's Avatar
You MUST go higher. If you have a 12V AC, the rectified DC can go to 20V unloaded. Then when the AC reverses, the back-end of the diode (the anode) can go down as much as -20V. So your diode will see almost 40V across it when not conducting...
Jan
If you don't change your beliefs, your life will be like this forever. Is that good news? - W S Maugham
Check out Linear Audio!
Old 13th July 2014, 12:35 PM   #8
coresta is offline coresta  France
coresta's Avatar
http://http://www.diyaudio.com/forum...-question.html
Same Resistor to use? XsamuraiX Parts 4 11th April 2014 03:16 PM
RESISTOR VALUE ABCD1 Forum Problems 1 5th June 2012 10:20 AM
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Are you using the resistor? Ricren Chip Amps 8 16th May 2003 08:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
