Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Mundorf polyprop x Rodenstein MKT listening test preparation
Old 5th February 2014, 08:59 PM   #121
fas42 is offline fas42  Australia
Banned
Sorry, Pavel, turned out to be a 'medical' day yesterday, first chance this morning to listen, thanks for the posting!
Straightaway, speakers and DAC dead cold, in worst listening state, orig was so superior, way in front of cap2. The giveaway, the quality of the cymbals, in the 2nd half of the snippet - in orig this was the first time the tone of these actually worked as reminding me of the real thing, even though the playback was relatively poor. Going across to cap2 and wire, yes, the cymbals were there, but they were relatively anonymous, the sparkle of the real thing was severely curtailed, in comparison.
Old 6th February 2014, 05:29 AM   #122
PMA is offline PMA  Europe
PMA's Avatar
Thank you, Frank. Your observations support the fact that even a cheap PC audio system with plastic speakers should be supplied with the best possible sound data, both to be pleased by listening and to get usable output from listening tests.
Old 6th February 2014, 09:17 AM   #123
PMA's Avatar
I get 7/7 ABX result when I compare the original sound file with D/A - wire- A/D sound file. Matched and aligned, of course. Listening in a second room through open door, sitting at my PC, the biggest difference is in the sound impact.
When doing cap1 x cap3 (Mundorf x Roederstein), I get 2/7 result, or something similarly random when repeated.
The conclusion, to me, is like this: there is a big difference after applying a commercial D/A - A/D chain to the original data. I would need something like Meitner system. Thus, even if there was a subtle audible sound difference between the caps, it would be very difficult to catch it, without having the best SOTA D/A A/D hardware available.
Old 6th February 2014, 09:52 AM   #124
Mooly's Avatar
Yes... but could it be argued also that each file, the original (off CD) and the A/D-D/A file can each be viewed as unique and valid.
Are you meaning that the extreme subtleties of for example, the inclusion of a cap in the A/D D/A chain would be non-detectable because the whole chains resolution is not high enough.
Is it possible I wonder to ABX two "identical" recordings made through the same A/D D/A process where the only difference is that they are two takes of the same recording.
There must be some "baseline" at which tests like these do become detectable to the listeners. Maybe that is worth exploring because if the "baseline" becomes so huge then it means the test process isn't working as intended. The trouble is that the software and the people skilled in using such software can seemingly pick the tiniest details from files and that has to sway the result. Sit them down and say "listen" and the results are probably much more blurred.
Hmmm... interesting.
Old 6th February 2014, 10:10 AM   #125
miero is offline miero  Czech Republic
Several rounds of D/A A/D re-recordings might help to reveal what is added or lost during this process.
Old 6th February 2014, 10:12 AM   #126
PMA's Avatar
Certainly. Cap1 and cap2 were two files recorded through same path. Their difference is a noise signal, maybe with some subtle sound modulations, and no one has posted any ABX result that would proof an audible difference. Only unsupported claims on clearly audible differences.
The whole chain error must be the smallest possible, to perform such tests like these are. If the original x D/A - A/D chain is reliably distinguishable, then the resolution to pick up audible differences between capacitors is insufficient, even if they existed. We can only say we did not found them under existing test conditions. We cannot say they do not exist.
Old 6th February 2014, 10:13 AM   #127
Mooly's Avatar
Good idea. That could reveal something although again, software analysis always seems to reveal some difference when there are two files to compare.
Old 6th February 2014, 10:13 AM   #128
PMA's Avatar
We have repeatedly tested this, with positive results. Even here at diyaudio.
Old 6th February 2014, 10:18 AM   #129
Mooly's Avatar
This is the crucial part as I see it, and why trying to determine a baseline of what can or can not be detected audibly (and that is the important part) is perhaps important to any future tests. And listeners have to be confident to say which they actually prefer whether it be a cheap device under test or a SOTA device and not just say, yes there is a difference.
Old 6th February 2014, 10:25 AM   #130
PMA's Avatar
Yes, valid only and only under the test conditions used. No generalization is possible then.
In my system, A/D is the biggest issue. D/A is always the same and the difference between sound of D/A only and sound of D/A-A/D recorded file is reliably detectable.
Mundorf polyprop x Rodenstein MKT listening test preparationHide this!Advertise here!
Listening Test 2 Mooly Everything Else 1 24th November 2013 10:25 AM
Listening Test 1 Mooly Everything Else 5 24th November 2013 10:24 AM
Ultimate listening test ... test your ears and audio chain PMA Everything Else 378 21st November 2013 10:20 AM
Resistor and Capacitor Listening Test SY Parts 45 30th August 2011 05:12 PM
Listening test of drivers ginetto61 Multi-Way 16 1st December 2009 05:48 PM
