Hi, I bought a new smt750 ups for my pc-audio
but I have some problem for turn off this device (from panel)
because this is enough complex.
(Turn on ups is very simple, just press the on-button )
To turn it off:
1 - press the on / off button
display ups ask: ups turn off? no/yes
2 - I have to select "yes"
3 - I have to press enter button
display ups ask again: Ups Control? (off-use Delay / Off no Delay/ Reboot use Delay / Reboot no Delay / No Action)
4 - I have to select the "off No Delay"
5 - I have to press enter button again
Finally, it turns off.
(alternatively I have to hold down the off-button for over 14 seconds until the second beep)
I understand that this system is designed to prevent accidental switching off,
however this is quite uncomfortable.
(the old sua750 was much simpler)
any ideas?
To turn it off:
any ideas?
Thanks for the reply. Yes,I should shut it down through the program powerchute.
The problem is that I also use a lot of live linux cd-rom and so I have to turn it off from front panel.
I bought this ups because I only need true sine output, I hope that the new BIOS versions are less complex.
