Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Purely subjective test. Which do you prefer.
Old 26th January 2014, 07:14 PM   #31
sgrossklass is offline sgrossklass  Germany
Seems the problem simply is input common-mode range. The TLE2072 is given with +5/-1.9 V typical on a +/-5 V supply, and there's a unity gain buffer in there that has to swing down to -2.83 V, as do its inputs. Which would correlate with distortion setting in a little under the -3 dBFS mark. The NJM5532 typically does +/- 3 V under the same conditions, hence no problems. (Got any mean >0 dBFS test signals like that fs/4, 90 sine? That ought to be it.)
For kicks, one could try a TL072... Inversion time!
Clearly a case of "plug'n'pray". Those are the perils of low supply voltages and non-RRIO opamps.
Old 26th January 2014, 08:33 PM   #32
BYRTT is offline BYRTT  Denmark
So in this "plug and play electric" case seems only a voltage problem ("plug and play hardware" also needed attention where Mooly did a converter).
Old 27th January 2014, 06:34 AM   #33
PMA is offline PMA  Europe
PMA's Avatar
The distortion profile clearly showed clipping, as I have already mentioned.
Old 28th January 2014, 09:52 AM   #34
Mooly's Avatar
Something different,
Purely subjective test. Which do you prefer.Hide this!Advertise here!
Really subjective question regal Tubes / Valves 24 1st March 2010 10:02 AM
Subjective evaluation consort_ee_um Everything Else 0 6th December 2007 10:21 AM
THE best subjective sound ? medogrizli Solid State 11 30th May 2007 11:56 AM
Subjective lunacy mikeks Solid State 24 18th September 2006 02:36 PM
purely resistive crossovers? googler Multi-Way 38 25th March 2005 07:04 PM
