Purely subjective test. Which do you prefer. - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 21st January 2014, 12:15 PM   #21
Audacity has no difficulty in resolving HD of 1kHz signal.
What is design role of this amplification stage?
What is input signal from previous stage? How is this loaded by input of 5532 v TLE2072?
How are outputs loaded? Output impedance of these two chips appears to be quite different.
I time aligned OMNICRON/Pi to put this out of my mind, and just listened. ABX confirmed ability to hear difference. I didn't make subjective choice before results revealed.
Distortion spec for TLE2072 is certainly nothing special, but likely much better than distortion of recording chain. How this rolls into "sound" or "sound quality" loops into seeming endless topic, regardless of recording/playback chain.
For most, pure 2nd harmonic -36dB is somewhat above threshold of audibility with single tone stimulus. But being so far above TLE2072 spec strongly suggests poor plug and play implementation in swapping out 5532.
Thanks for your efforts, look forward to your next adventure.
Old 21st January 2014, 12:29 PM   #22
Mooly's Avatar
Poor "plug and play" sums this one up brilliantly. Given that many like the sound of equipment that lets say "emphasises" certain distortions I thought this would make an interesting test. Those with "cold sounding" amps might have warmed to the distortion added by the TLE2072. The stage is just the typical opamp output circuit in many a CD player, this one hampered by 5 volt rails although in stock form there doesn't seem to be a problem.
Unfortunately there were not enough participants in this test... oh well
Old 21st January 2014, 12:56 PM   #23
PMA is offline PMA  Europe
PMA's Avatar
Low resolution/dynamic range in both amplitude and bin width. You can see it in Mooly's images.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 21st January 2014, 12:59 PM   #24
PMA's Avatar
Karl, this is completely wrong track. Compare NE5532 with OPA627. There will be no excuse to distortion in case of OPA627. "Cold" or "warmer" sound has nothing in common with harmonic distortion as low as is in case of opamps.
Pavel Macura
Old 21st January 2014, 01:38 PM   #25
In case of 1kHz, and Audacity's 16k FFT limit, bin width is more than sufficient for resolving distortion limits of TLE2072 spec, and virtually any loudspeaker played at any level.
Old 21st January 2014, 09:06 PM   #26
fas42 is offline fas42  Australia
Banned
Also, there is no problem with amplitude range in Audacity, I can easily see beyond 120dB - it's just a configuration setting ...
Old 21st January 2014, 09:19 PM   #27
PMA's Avatar
Sorry, sounds like empty phrases to me. Would you show any measurement like this made with Audacity?
Pavel Macura
Old 21st January 2014, 10:31 PM   #28
Pavel,
Many surgeons prefer stone knives.
I'm not advocating Audacity as tool of choice, but it is remarkably powerful, open source, and quite workable.
Here is 1kHz 0dBFS with 3khz -115dB with 1024 bin FFT:
A throwback to when digital tools were scarce, and very expensive. Since 1kHz is known stimulus a notch filter is applied, available as Audacity effect, and result becomes:
The notch filter is narrow and clean enough for resolving 2kHz harmonic too.
Old 26th January 2014, 01:49 AM   #29
This is an I/V and more importantly filter stage. I haven't simulated it, but my guess would be that it might be a little hard on the opamp's output stage. Which could explain why the much beefier 5532 did just fine while the TLE2072 (with load immunity being about a factor of 4 worse) struggled. Filter circuits may also exhibit higher internal levels. I guess I'll just sim the thing tomorrow.
Old 26th January 2014, 06:29 AM   #30
Mooly's Avatar
Try this. I find that opamp sims aren't always reliable but must admit that here and using a FET opamp... well the result is obvious. The effect on a scope wasn't quite this bad and no tendency to hard clipping. And this is at way below the -/+2.8 volts pk/pk that 0db gives.
File Type: zip CDP790 Output Filter.zip (980 Bytes, 3 views)
Really subjective question regal Tubes / Valves 24 1st March 2010 10:02 AM
Subjective evaluation consort_ee_um Everything Else 0 6th December 2007 10:21 AM
THE best subjective sound ? medogrizli Solid State 11 30th May 2007 11:56 AM
Subjective lunacy mikeks Solid State 24 18th September 2006 02:36 PM
purely resistive crossovers? googler Multi-Way 38 25th March 2005 07:04 PM
Copyright 1999-2017 diyAudio
