Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 11th December 2013, 11:42 AM   #1
PMA is offline PMA  Europe
PMA's Avatar
Default Small signal myths and real measurements
More and more posts in the forum deal with pseudo theories and unsupported claims about mysterious small signal distortions in circuits with negative feedback. I would like to post some of my measurements that prove that opposite is true in case of 'normal' design. I would like to encourage the others as well to post their results.
I am starting with a link-level preamplifier based on OPA627 and DRV134 and measurements related to 0dB = 146mV. I will appreciate your comments on 'small signal distortions'.
Pavel Macura
http://web.telecom.cz/macura/audiopage.html
Old 12th December 2013, 02:48 AM   #2
fas42 is offline fas42  Australia
fas42's Avatar
Pavel, would it be possible to do some IMD measurements on that component, where the level of the 2nd signal is down -20, -40, -60, etc, compared to the 1st - to satisfy my curiosity ...
Thanks,
Frank . . . everyone knows what a 'bad' recording is - it's one that doesn't sound good on their own, very special system ...
Old 12th December 2013, 03:11 AM   #3
jcx is offline jcx  United States
https://web.archive.org/web/20101203...m/tmt_1002.pdf
I find the intersting part starting ~ p15 - the ever popular external Class A bias of an op amp output - but with actual measurements
Old 12th December 2013, 05:49 AM   #4
PMA's Avatar
Thanks,
Frank, I appreciate your curiosity. Reducing amplitude of the 2nd signal only makes things easier for the amplifier.
1) 19+20kHz. All intermodualation products disappear and the only product you can see is the 2nd harmonic of 19kHz, i.e. 38kHz, about 96dB below 19kHz line level. Further reducing of 2nd signal amplitude brings no change so please allow me not to post images.
2) 1+20kHz. No intermodulation products available.
The conclusion is that smaller the signal components less work for the amplifier, in this circuit under test.
Pavel Macura
Old 12th December 2013, 05:54 AM   #5
PMA's Avatar
Thanks for the link, this is a good and interesting publication.
We may also replace rail resistor by self-biased JFET.
My question - in case of 1mA output stage idle current and 10k load the output pp stage would remain in class A up to 20Vp output voltage (never used in a link stage). Does it make any sense to use output stage supply resistor then? I understand it may make sense for 600 ohm load, but then I would go for a BUF634 or discrete buffer.
Pavel Macura
Old 12th December 2013, 06:33 AM   #6
PMA's Avatar
Also interesting is no big influence of heavy load in case of small signals. Output impedance is 50 ohm, please compare effect of 10k and 50 ohm load. We can see the plot shifted down by 6 dB (50R : 50R divider). 0dB = 150mVrms approx., as shown in 1st post of the thread.
Pavel Macura
Old 12th December 2013, 06:38 AM   #7
frugal-phile(tm)
planet10's Avatar
Test using sine waves?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th December 2013, 06:50 AM   #8
PMA's Avatar
Would you prefer cosine?
Pavel Macura
Old 12th December 2013, 07:03 AM   #9
frugal-phile(tm)
planet10's Avatar
I would prefer real music. The tests with easy to reproduce periodic signals can really only prove something about periodic signals.
dave
Old 12th December 2013, 07:08 AM   #10
Bonsai is offline Bonsai  Taiwan
Bonsai's Avatar
"Would you prefer cosine? "
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Amplifier distortion with music signal (measurements inside) mr_push_pull Everything Else 80 26th June 2013 11:44 AM
Help with real measurements on the Fostex FE126En and the FE103En fullrange Drivers? cross reference Full Range 9 18th February 2013 08:32 AM
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
DIY Thiele/Small measurements ?? youyoung21147 Full Range 19 5th October 2005 05:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
