Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 18th November 2013, 09:17 PM   #1
JoeDJ is online now JoeDJ  United States
Default Does it matter how/where an EQ is connected?
Using an integrated amp with external pre/main jumpers, does it make any difference (sonically) where you "place" a graphic EQ , either between pre and main or, in a tape monitor circuit?
Yes, I realize that in a tape monitor circuit, it can be easily be switched in and out with the amp but, the EQ can also be bypassed by a switch on the EQ.
Is there anything other that that I should be aware of ?
Old 19th November 2013, 01:39 AM   #2
Enzo is offline Enzo  United States
I used to have a little consumer graphic EQ, and it instructed me to use the tape loop. The unit had its own tape loop on the EQ, so I didn;t lose that function.
But the whole point of an EQ is to fine tune the freq response of the audio to compensate for the variations in the speakers and listening environment. Between preamp and power amp is the natural place for it. SO if you have the pre/main jumpers on your system, then why not use them, and leave the tape monitor for its intended purpose?
Old 19th November 2013, 01:54 AM   #3
Yeah, actually I was leaning toward between pre & main..
It will be for a NAD c350 that I'm getting....... using my vintage Teac EQ.
Old 19th November 2013, 01:58 AM   #4
Yes it does depending on details. Should be best pre to power amplifiier.
However in a tape loop easy to ascertain sonic degradation set to flat.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 19th November 2013, 02:09 AM   #5
OK, sreten.
Old 19th November 2013, 03:03 AM   #6
After re-reading your post.......
The EQ has a switch to bypass the EQ for "flat" comparisons, etc.
Old 22nd November 2013, 04:42 PM   #7
Actually, I may just keep is as I presently have it which is.....
All inputs are connected to a mechanical source switch with no crosstalk .
The source switch output is connected to the EQ's input.
The EQ output is fed into the amp's pre input. .
This way I can listen to my headphone amp connected to the EQ's tape out by just hitting the EQ out" (flat/bypass ) switch (with the EQ turned off) to feed a flat signal to the headphone amp with the rest of the system (Amp, sub, and EQ) turned off..
Old 22nd November 2013, 05:45 PM   #8
If your system has very low distortion, witch I presume it has, than it makes little difference. An EQ is a linear distortion device and linear distortions can be added just like numbers. So a+b=c and b+a=c to.
But if your system has higher distortions, then the outcome is very different as you can't add non linear distortions and linear distortions. So a+b=c and b+a=d
Old 22nd November 2013, 07:05 PM   #9
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Eq's are best left in the studio , no need to eq the eq ...
On the floor looking at the great ones and drooling ..... :
Old 22nd November 2013, 07:24 PM   #10
cbdb is offline cbdb  Canada
Between pre and amp may have more noise. If the eq is before the volume the volume control turns the eq noise down with the signal if it's after, (after the pre) the eq noise will be maximum no matter where your volume is set. The tape loop is the same as pre volume.
Biamp EQ-210 as a "Studio" EQ? techbiker Analog Line Level 18 25th November 2012 09:43 PM
Available EQ on combined electronic crossovers/ EQ: Berhinger, dbx, etc rick57 Digital Source 2 10th May 2011 02:09 PM
amplifier works connected to PC .. but not when connected to car radio anwaypasible Analog Line Level 1 2nd March 2011 07:42 PM
Passive EQ to active EQ Nuuk Multi-Way 13 24th May 2004 07:59 AM
Available EQ on combined electronic crossovers/ EQ: Berhinger, dbx, etc rick57 Multi-Way 10 11th June 2003 10:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
