What value resistor is this? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th October 2013, 04:25 AM   #1
redrooster's Avatar
Default What value resistor is this?
I found a Conia LCD TV CL2202FHDVD at the recyclers and decided Id try to fix it Ha! It has a 12vDC external power supply and where it plugs in there is a 1 watt resistor that appears to have gone open because I cant get an ohms reading with my DMM. It has only three colors instead of four? green,black,red, or red,black,green. So is it 2million ohms or 5k ohms or something else? I don't want to put the wrong one in and maybe burn it out.
Old 13th October 2013, 05:11 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Have you double-checked your DMM?..because it doesn't look damaged, burn't or otherwise defective. Being as the center band is offset to the left, I would read it left to right as pictured here. Does your DMM go up past 2Mohm?
Check others in your unit, it looks brown in color in the picture, compare it to others..making sure that is "black" as I see it.
__________________________________________________ ____Rick............
Old 13th October 2013, 06:13 AM   #3
redrooster's Avatar
I have 3 DMMs,2 digital and 1 analog,they all measure it the same (no reading)? The digital DMMs go to 200 million ohms.The middle color is definitely black,its that black even the white bits are black Ha! On the PCB board where the resistor goes it reads; TP11 + 12v F51. or the last bit maybe FS1? Fusible resistor? I hate it when $#@% manufacturers don't play by the *#%@ rules.Its 4 colors not %&@# three! LOL Maybe fusible resistors are different?
Old 13th October 2013, 06:29 AM   #4
sofaspud's Avatar
It's not much help, but that's what I was thinking.
I could be wrong, but I don't see why a 12V automotive lamp couldn't be used for a series bulb tester...
...with a jumper in place of the fuse, in order to continue with the LCD repair.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 13th October 2013, 06:41 AM   #5
redrooster's Avatar
OK Ill give it a go but I havent got a 12v auto bulb handy,would anything else do?
Old 13th October 2013, 06:56 AM   #6
sofaspud's Avatar
A 12V bench supply with adjustable current limit.
If you can look at the external supply and get a good idea of what current the TV should draw, you could place an inline fuse in the supply line (using pigtail leads soldered where the 'resistor' was).
You did search online for docs for this unit?
Old 13th October 2013, 08:18 PM   #7
Fonebones's Avatar
Is it sure that it was a resistor? Some inductivitis have the same look.
If it is in series with the supply even 5K seems to be pretty high.
suus cuique crepitus bene olet
Old 13th October 2013, 08:32 PM   #8
diyAudio Member RIP
Hi, Its obviously 5K, its not in series with the supply, rgds, sreten.
Old 13th October 2013, 11:32 PM   #9
redrooster's Avatar
Yes I searched online but there isnt a service manual according to Conia head office, eventually I was passed on to a service repairer who asked me what the problem was so I replied with the details but never heard back?
Old 13th October 2013, 11:48 PM   #10
redrooster's Avatar
Maybe its an inrush current resistor,not in series? Because I remember now that I was getting voltage 11.9v on another board when I was doing some measurements.The external supply is rated 12volts 4.5amps. What would the value be for an inrush resistor?
Help with resistor Deadly Sones Car Audio 2 12th August 2013 06:00 PM
RESISTOR VALUE ABCD1 Forum Problems 1 5th June 2012 10:20 AM
help with resistor moss99 Parts 13 2nd July 2010 05:07 AM
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Copyright 1999-2017 diyAudio
