Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
What value resistor is this?
Old 14th October 2013, 02:41 AM   #11
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Originally Posted by redrooster View Post
On the PCB board where the resistor goes it reads; TP11 + 12v F51. or the last bit maybe FS1? Fusible resistor?
That pretty much clinched it for me.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 14th October 2013, 04:08 AM   #12
redrooster is offline redrooster  Australia
redrooster's Avatar
Could you expand on that a bit,I'm not sure if I'm clinched at all.LOL What do you think it should be? A 5k ohm I watt Fusible resistor?
Old 14th October 2013, 04:33 AM   #13
sofaspud's Avatar
The board identifier clinched it as a fuse. A fuse is only good if it is in series - otherwise the current can just ignore it, whatever it does.
Now the value...
The bands are coded for 5, 0, and 2.
2 ohms and 5 amps seems to me the most logical fit with a 12V 4.5A power supply. (I'm going by memory; I didn't go back a page and check the ps rating.)
edit: Actually, 0.2 ohms makes more sense.
But I would likely just replace it with a regular fuse unless an exact replacement fell in my lap.
Old 15th October 2013, 02:33 AM   #14
redrooster's Avatar
Now the value...
Thanks for taking the time and trouble to help me with this,Its appreciated.
Old 21st October 2013, 10:48 AM   #15
redrooster's Avatar
That was it!!! I used a 5watt 0.5 ohm resistor and it fired up straight away,I couldn't find a 5watt,0.2 ohm resistor. I will try a fuse in there and see what happens.
What value resistor is this?Hide this!Advertise here!
Help with resistor Deadly Sones Car Audio 2 12th August 2013 07:00 PM
RESISTOR VALUE ABCD1 Forum Problems 1 5th June 2012 11:20 AM
help with resistor moss99 Parts 13 2nd July 2010 06:07 AM
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 07:12 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 04:18 AM
Copyright ©1999-2017 diyAudio
