Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Circuit Help needed for graphic equalizer using LM3915
Old 13th September 2013, 06:30 PM   #21
sandiegoman is offline sandiegoman
These are clickable now. Looks like the main differences are the caps used to split the bands.
Band 1 uses a .047 prior to going in to the LM3900 and another .047 that goes around and meets up on the output.
Band 2 uses a .012 before going in and another to the output.
Band 3 uses a .001 prior to going in and a .0022 that goes to the output.
So I wonder if I change the caps to somewhere around .006 for a new band and 2 .024 on the other if that will give me 2 more near the middle. Then I can use 2 of these kits to provide the 5 different bands I need.
Use the link below to see larger image:
http://reactivelights.com/wp-content...9/canakit1.jpg
http://reactivelights.com/wp-content...9/canakit2.jpg
http://reactivelights.com/wp-content...9/canakit3.jpg
http://reactivelights.com/wp-content...3/09/myeq1.jpg
http://reactivelights.com/wp-content...3/09/myeq2.jpg
Old 16th September 2013, 06:09 PM   #22
Success! Well, so far... I swapped out the caps and it still works!
I will be doing a full scale test of the LED panel that I made later today and will post images. In the meantime, if you want to see the progress, you can check out my website Reactive Lights | Audio Reactive Lighting Systems
Both of my kids are soldering now, so we are having a good time!
Circuit Help needed for graphic equalizer using LM3915Hide this!Advertise here!
5 Band Graphic Equalizer NSLogan Chip Amps 2 17th June 2009 03:52 AM
DIY Graphic equalizer? coldfuzion76 Solid State 4 18th March 2008 08:45 AM
Graphic equalizer Buzzy Parts 1 24th July 2007 07:55 PM
Graphic Equalizer design HELP needed hrg2112 Solid State 4 21st December 2006 07:06 PM
Graphic Equalizer Johnny25 Parts 5 29th March 2006 05:33 PM
Copyright ©1999-2017 diyAudio
