Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th December 2003, 10:50 PM   #1
Send a message via ICQ to Drew
Default DIY Lighting Control Help/Ideas/Theory
Hey everyone,
I want to build a lightning control module for my home theater system.
I have a theory but not sure if this will work or not, but here it goes:
Take 10 - 12v Relays and mount them on a panel.
Take the 12volt trigger and attach that to the 85 side of the relays.
Take -12v (ground) and attach that to the 86 side of the relays.
Take the neutral AC wire and attach that to the 30 side of the relay then connect the other side of the neutral AC wire to the 87A side that goes out to the lights.
Theory is that when the +12volt trigger is received, then the relays will cut the neutral wire going to the lights.
Is this possbile?
Or am I outta my mind?
Drew
Old 14th December 2003, 03:54 AM   #2
PassFan is offline PassFan  United States
The National Electrical Code prohibits the switching of a neutral wire unless the corresponding hot wire is also switched by a device that switches them both at the same time. Switching a neutral is a safety hazard as well as a fire hazard. There are low voltage relay systems available that can work, I would suspect, for what you want to do. They are fairly common for residentioal use.
Old 14th December 2003, 05:01 AM   #3
li_gangyi's Avatar
why dun you cut the live wire??
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 20th December 2003, 12:42 AM   #4
pinkmouse's Avatar
Best practice is to switch both live and neutral, but leave ground connected. However, I believe that X10 type control stuff is easily available and relatively cheap, so if you are not sure of the safety aspects, then that would seem to be the way to go.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 20th December 2003, 02:20 AM   #5
RIC is offline RIC  United States
Just swap for the live wire, thats the only safe way, plus figure
your load to main feeder, and put a beaker inline. and you should be good to go.
Ideas 4 final year project in control systems & instrumentation engineering momin Everything Else 0 22nd August 2008 03:04 PM
Sub lighting? Tommo Subwoofers 4 28th May 2005 09:40 AM
Page generated in 0.15571 seconds (43.78% PHP - 56.22% MySQL) with 10 queries
